General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
93 runner Alarm Nightmare!! Please help!!!
Old Apr 17, 2010 | 11:29 AM
J3rm_pbr's Avatar
So i am in the process of moving and I noticed that my brake lights weren't working. I checked the fuses first and noticed a 15amp that was fried so I replaced it. I also noticed a twisted piece of copper in a random fuse, there is an eyelet on the top of this copper piece but no wires to it and the copper wasn't joining any fuses together.
so anyway like a dummy i removed this piece and the nightmare begins.
My truck started fine and then after it was started my alarm went off. so I turned off the key thinking it would reset the alarm but no.. now the truck won't start at all. I have a load of my house belongings onn a trailer hooked up to the runner. I need help now please. Is there anyway to temporarily bypass the factory alarm? like by attaching a ground wire somewhere please help!!! I may be able to post pics if needed!!!!! Please help
1993 4runner 4wd 3.0v6 206,000miles
Old Apr 17, 2010 | 12:35 PM
GranVille-4crawler's Avatar
Did you try putting the copper piece back?
Old Apr 17, 2010 | 12:47 PM
J3rm_pbr's Avatar
yeah but I can't remember where exactly it was. I located my alarm ecu under my driver seat. I disconnected it and that didn't help, I tried disconnecting the battery pos+ and neg- and tried again. Same Problem. I just replaced the battery 2 days ago Duralast red top. But Yeah as soon as the battery cables go back on the horn starts.... (although I Located the Horn fuse under the hood and pulled that son of a'. Horn's Freakin' loud
Old Apr 17, 2010 | 12:49 PM
J3rm_pbr's Avatar
i've also gone as far as tryin to pull each fuse in the panel 1 at a time, turning the key after replacing each one. No luck. I appreciate anyone who takes the time to assist
Old Apr 17, 2010 | 02:32 PM
J3rm_pbr's Avatar
only update is that the copper was a cheap hookup for power and looking back i did remove a dash switch that had been installed
J3rm_pbr's Avatar
still not starting
icentropy
Sep 16, 2020 02:47 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
