General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Electric windows without key?
Old Oct 13, 2010 | 07:00 PM
landozion's Avatar
I camp a fair bit in my 3rd gen runner, and wonder if anyone has figured a way to rewire the windows so I can operate them without the ignition switch being on? I guess what I need is a way to keep those switches hot at all times. Any reason why I should not do this? I know just enough electronics to be dangerous, but ain't afraid to do some cutting and splicing. Maybe I will start another thread. but while I am asking stupid questions, anyone figured a way for a rear tailgate release from inside on a 3rd gen?
Old Oct 14, 2010 | 07:09 AM
aviator's Avatar
Not a silly ?... if you have the factory alarm this might not work but...
consult the shop manuals (FSMs) linked here and look up your power window diagram.
to find the wire in the harness that supplies power to the windows and change the source to one that is always hot either with a new wire run from the batt. directly and fused the same as the original feeder (safest) or piggybacked on another always hot circuit (lights? lighter?) in the fusebox with an (add a circuit) adapter (not as safe, might overload circuit).
the 2gen windows/locks are fused for 30amps so you know these are powerpigs the add a circuit max is 10 amps and it does work (on mine) but I do occasionally blow the fuse and have to replace it... usually when tracks get dry and window is binding a bit... window action is also slower compared to stock.
hope this helped
aviator
edit there is a thread here I saw one time on the inside tailgate release thing... try a search... also look through our tech articles wiki it might be there
Old Oct 14, 2010 | 07:38 AM
4Crawler's Avatar
Yep, basically what I did in my 1st gen:
- http://www.4crawler.com/4x4/CheapTri...l#PowerWindows
jasonty
41
Dec 23, 2018 01:00 PM
Poppie51
Aug 15, 2015 11:02 AM
TDonkey
Jul 26, 2015 10:14 AM
RustBucket
Jul 24, 2015 04:46 AM
icentropy
Jul 14, 2015 10:23 AM
