General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
electric window switch has dropped
Old Jul 29, 2010 | 01:57 AM
Linda's Avatar
2002 4runner front drivers door, electric window and door lock have dropped down into panel what caused this and can I fix rather than taking to shop?
Old Jul 29, 2010 | 08:43 AM
aviator's Avatar
The window switches are usually attached to the panel from behind with screws. It sounds like either the screws have come loose or the attachment points have broken or stripped. Either one can usually be fixed relatively easily.
Check our FSM (factory shop manual) links for your runner, and you'll be able to find out how best to get access to the area. You may be able to pull the cover plate or you may have to pull the whole inner door panel off IDK I'm not familiar with the 02 runners.
Hope this helped
coreyedwards7611
Jan 16, 2016 06:38 PM
RustBucket
Jul 24, 2015 04:46 AM
94yotaky
Jul 23, 2015 07:50 AM
icentropy
Jul 14, 2015 10:23 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
