General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Hella 500 on OEM Circuit, Good or bad idea?
Old Apr 12, 2010 | 09:46 PM
GorillaSalad's Avatar
A while ago I installed my Hella 500's using the power leads going to the old OEM fog light wires on my 4rnr. I figured after I replaced the bumper and trashed the fog lights I could use the vacant power leads. Great thing is I didn't have to wire anything up and i retain the stock on/off switch at the steering wheel. Im wondering if that was a bad idea. I have not had any issues thus far. I'm not sure what the spec is on the old fog lamps and what maximum draw should be for the OEM circuit. All I know is the hella's are 55W.....
Also I notice HID's are 35W which is less than their Halogen counterpart. Do the the HID's draw less amps or more? I'm thinking of upgrading but I'm not sure if my current set up is safe, much less putting HID's in their place.
Any tips are welcome.
Old Apr 12, 2010 | 09:55 PM
Elton's Avatar
that factory wire is probably tiny id just rewire it with a relay to be safe
Old Apr 13, 2010 | 08:41 AM
Yeah, I would love to keep my stock on/off switch. I'll look into rewiring the circuit thats there. The factory wire is thin, very thin maybe 18 AWG. Im not sure but I think it uses the same relay as the headlights.... Anyway food for thought.
Old Apr 13, 2010 | 09:21 AM
dropzone's Avatar
Fossilized
i tried it on my old '05 Tacoma's factory foglight circuit..blew the fuse on the 1st flip of the switch...but with the HID's you might be OK, my HID headlights draw less power. Rewiring would be the safest bet though
Old Apr 13, 2010 | 09:23 AM
aviator's Avatar
The HIDs draw less amps than Halogens for a given output... it's one reason why they are one of the options folks are converting to...
The stock wiring should be able to handle it but is very small and is also probably getting a bit worn... I would keep it but use it as the trigger wire for a relay and run the lights on a separate fused circuit straight from the batt. using 14awg as a min size. The lights will be brighter and everything will run cooler as well.
Old Apr 13, 2010 | 03:23 PM
Deceptiwave's Avatar
I am going to use the factory wiring for the relay switch on my 2002 with the 500FF as well.
Old Apr 13, 2010 | 04:40 PM
Thats a great idea thanks for that. Ill post a how too in this thread when I get it rewired. Thing is I might as well upgrade the 500 to HID's while I'm at it too hu... Thanks again all!
Old Apr 13, 2010 | 05:48 PM
Elton's Avatar
id love to upgrade my lights to hid but i use them on the road so turning them on and off would just ruin them
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Regency
20
Jan 3, 2020 07:43 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
