General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
id brake light wire
Old Jun 26, 2010 | 05:22 AM
Truck15's Avatar
id brake light wire
what is the best way to identify the brake light wire on a 2003 tacoma? I need to connect to hook up 3rd brake light for truck cap.
Old Jun 26, 2010 | 07:56 AM
4Crawler's Avatar
Well, one way is to look up the wiring colors in a Factory Service Manual wiring diagram.
Another way is to pull the tail light assembly out and see which wires are hooked to the brake light bulb. Likely a dual filament bulb, so either trace the wiring in the socket or use a meter or test light to find the wire that gets power with the brakes applied.
Old Jun 26, 2010 | 08:25 AM
Truck15's Avatar
thanks, couldnt see the forest thru the trees. when I connect the ground from the cap light, does it need to go to the ground wire for the brake light?
Old Jun 26, 2010 | 08:29 AM
4Crawler's Avatar
Probably would be a good idea, and you have to run the power wire anyway, so just as easy to run 2 wires vs. 1.
Old Jul 2, 2010 | 08:33 AM
scope103's Avatar
Probably. Much to my surprise, it appears that the bed on my 1994 pickup is insulated from the frame! (Probably for noise reasons, not electrical.) When I installed the in-cap lighting I had to pick up the ground from the taillight assembly.
smthwsn357
May 1, 2024 07:28 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
