- Lights on HELP.. trans light, charging light, and brake light
- 03 camry starter relay
- wire unknown
- ASC Button on moon roof?? Anyone know what this is for??
- 1st gen toyota charging problem
- 86 4Runner power windows. I want to redesign the circut
- Cruise Control
- Fuel pump shutoff switch
- ECU Clicking?
- Cool site for fuse taps and more
- Light install gone bad
- Horn not working
- Newer Toyota Fog Switches
- Interior reverse light?
- Fan Switch Problem ...HELP...
- Interior lamps question...
- Replacement Hella Lens?
- 94 Land Crusier Driver window controls
- wire harness
- Do Toys have "flood Clear" logic in Computer
- Power Antenna On/Off Switch
- I Want To Put Some Lights On!
- Need Help with Power Window/Lock/Mirror conversion
- Whats this wire for?
- Hella FF1000s in the mail
- Problems with rear defrost
- Don't have 12V power when truck is turned off
- My headlights are switching on in the middle of the night!
- makeing your turn signals light up
- 12V Switching Wire??
- Using an OHM Meter
- Fog Light Question: 2006 Taco
- 2nd Gen Battery Grounded Itself. Need Diagnostic help.
- trying to test my Throttle position sensor
- How are the dome light wires ran?
- RH signal woes
- I seem to have a short. I need to know where to start looking.
- aftermarket power locks and windows
- A few things drivin me crazy...PLEASE HELP
- Can I wire a relay this way??
- Need advice on wiring up switches to operate new aux lights
- power outlets
- Headlight Problem
- 89 color codes for oxy sensor
- what alarm do you guys use
- Overcharging Problem
- 4 crawler harness
- pro comp lights on toyota switch
- Bulbs (mini?) for my dash 85 4runner
- Rear 2" Fog and 2" Reverse LEDs
- Wiring up Hellas = Not working + Smoke!
- Ticket for Uncovered Lights?
- Starting to drive me mental
- Hella 500
- No Horn
- RH turn signal randomly flashes on/off
- anyone have the pioneer DEH 1600 head unit...got a couple questions
- Bad Battery or alternator, how do i tell which?
- anything better then Silverstars?
- '90 4-Runner, Where's the Starter?
- LED Reverse / Backup lights 2nd Gen 4Runner
- Where Is Your CB Antenna Mounted?
- For those with the Hunter bull bar (similiar to Westin)
- Who has the IPF fogs in the FJ Cruiser ARB bumper?
- fog light switch
- Alarm siren/speaker placement
- can you identify this wire?
- Alarm wiring issues 2nd gen pickup Help
- How To Intall Amp And Sub Wire?
- auto rear window
- Keyless entry problems
- Hella's with city light
- Schematics Needed!!
- Fog light install problem
- Rear cargo lighting in 3rd Gen 4runners?
- 4runner rear window
- high beams problem
- Rear locker mod
- In cab winch controls
- LED Lighting Wiring
- Fuel side electrical issues
- Symptoms of Bad Alternator?
- furl injector electrical fix gone wrong
- Lexus Licence Plate Lighting.
- Side Markers that Blink and Stay On.
- cruise control button for lights
- Power window switch rewire
- Need Help finding this lens
- lights
- How do I make my park lights double as blinkers?
- elec. inverter?
- locating the dome light wire
- Running Fog lights w/ High beams
- Dual battery system for gen2?
- Horn Upgrade
- Daytime running lights
- For those of you interested in HID projector retrofits
- hella 500's...any wattage?
- 80 4x4 pickup killing battery
- Tapping into high beams aux. lighting question
- Viper alarm install need some pointers
- Quick question about wiring LED lights?
- Headlamp wiring harness questions
- rear wiper intermittant switch wiring.
- Footwell LED project complete
- No gauge lights?
- horn problem
- ignition coil ground wire
- Spark Plug Issue
- What bulbs do you use?
- no spark from the igniter!!
- Scan Gauge II
- headlight conversions
- Odometer/Speedometer only working intermitently?
- RPM's drop a bit when I turn my lights on?
- What ohm meter are you guys using?
- Question about offroad lights??
- ipf 968
- Hard to start 3VZE v6, esp when hot
- Mystery plugs under dash revisited with photos
- Wiper control modual
- Real-World Pictures of your Auxiliary Lighting Output
- license plate lights
- What do you use for back-up lights?
- Power mirrors
- Fast Turn Signal
- Wiring rad. Fan override Indicator light
- Fuse blows could it be the relay??
- Need help brainstorming/troublshooting electrical short
- 2nd Gen 4R is killing batteries . . . why?
- Dash Lights And Dome Light Not Working.
- Silence of the Horn..
- Distribution Box - Electral for mods
- 96 4Runner Hazard lights power source?
- Rpm Gage
- 1 Alt, 2 Batts, no Solenoid
- Battery reverse polarity!
- Starter Issue - Researched but Need Advice
- Wipers don't shut off
- Need RS3200 alarm wiring diagram
- I think my alternator is DOA
- Speaker questions
- IPF wiring harness & Hella 500 lights
- is it the starter or the battery
- headlights/reverse lights kill engine
- Auto Light Shut-off Quit Working
- Grey Wire mod, Mystery wire?
- Relay Help
- Hella micro De's popping fuses
- I need a connector!
- Hella Comet 500
- 4th Gen 4runner Valor DVD/Navigation NVG-670WT installation
- Fuel Guage
- quick wiring help
- How much to change battery wires?
- hella 500 mounting difficulty on stock bumper
- 1985 22r Carburetor electric choke
- Power antenna switch.
- wiring in a elec winch ?
- Howi s this possible?
- Digital Clock Wiring
- Distributor Cap Rotor Question
- Need help installing xm my fi in 04 4runner
- Charging problems...tired of being pushed off
- 4WD light not coming on: how to fix it
- brake light problems
- Roundeyes conversion headlights
- '93runner no reverse lights
- 1985 Power window/door lock conversion
- Source for New headlights
- Electrical- lights
- What could be wrong w/ my keyless entry? Long story.
- Suggestions on hooking up a programmable license plate frame?
- Tach Not Working
- Battery not charging
- info on basic automotive wiring?
- A/C question
- Here is a good wire vs. current chart for everyone
- 92 toyota 4runner 3.0 firing sequence?
- Knock sensor location on a 22RE??
- 6 130w lights on a stock 22re?
- New Horns?
- question about pre-amp hookup in 2nd gen
- 3.4 swap, tach fix?
- help!!! no reverse lights in th350 swap
- Optima Battery Price Checks?
- 4Runner A/C Fuses
- Electrical Gremlins Ate My Truck
- My dual battery setup
- Momentary output to temp disconnect power to accessory?
- tacoma fog light switch wiring digrahm?
- What is needed to make my 4 pin harness into a 7 pin.
- electrical information needed for 3.0 3vzfe to 3.4 5vzfe.
- Speaker problems
- wiring kits
- 95 4runner a/c not working
- auxilary plug shorts out phone charger which blow acc. fuse help
- BIG 3 wire upgrade?
- High out alternator wiring help needed
- 1979 20R distributor/coil/ignitor problems?
- courtesy lamp
- cb indash mounting ?
- Spark Plugs,Dual electrode or single, 3.4
- Rear window defrost in my new truck
- Looking for a good wiring diagram?
- a/c lights
- silverstar vs vision plus
- A/C relay?
- Best Place to Tap into ACC Power?
- Lighted toyota fog/driving light switch won't light up
- Ignition Knowledge
- e-locker wiring
- Running lights aint working
- Diesel dual battery setup
- power window switches question
- wiring up 5 Roof mounted driving lights
- Starter Question!!
- 87 Pickup stereo wiring diagram
- 1988 Rear Window, Need Help
- VSS for gear driven transfer case
- 4Runner Rear Window Up/Down After Power Off?
- clicky starter? 82 yota
- charging probs (3.slow)
- Help with power locks
- 1986 4Runner: Wire from battery to fuse box (FL)?
- Best Driving Lights?
- Hot Main Fuse
- replacing wiring harness plugs
- Stock radio???
- Engine fuse blowing
- Foglights quit working
- CEL Code Help
- battery box?
- 3.4 Conversion Wiring Help.
- Gapping IK22 plugs question
- Where to supply +12V so the turn signals flash?
- Highbeams
- Lighters/outlets pulled out
- Factory Alarm Question
- radio screen not visible at night
- 1998 factory CD player skipping
- a/c shorting out... :( help?
- Try to start ..... Click
- Lo-Beam Headlights not working consistently
- Fog lights what's good what's the difference?
- Airbag and Horn stopped working at the same time...
- O2 Wiring
- power window issue
- Need help with Brake lights fast!
