General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
12V Switching Wire??
Old Mar 10, 2007 | 07:35 AM
OSU4Runner's Avatar
I'm trying to hook up my oil and voltmeter gauges. Does anyone know which wire to tap for a switching 12V+? Either the ignition wire or behind the radio?? What color are they? I have a 2000 4runner. Thanks
Old Mar 10, 2007 | 10:23 AM
4Crawler's Avatar
Get a volt meter or test light and probe the fuse block for a wire that gets hot with the ignition on. Otherwise, find a copy of a Factory Service Manual for the 2000 model and check the wiring diagrams (usually a good idea to test the wire for voltage even if you know the color). If your cigarette lighter turns on and off with the key, you can tap that power wire as well.
Old Mar 11, 2007 | 04:52 AM
MattGGT's Avatar
Cig lighter is probably the easiest to use, with regards to not having to use a meter. Think they are generally ignition switched. Or you could fit an auxilliary fuse box in the cab with a direct fused feed from the battery, to allow for later additions, and use a separate switch for the gauges.
Old Mar 11, 2007 | 06:57 PM
profuse007's Avatar
IGNITION 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
IGNITION 2 BLACK/RED (+) IGNITON SWITCH HARNESS
ACCESSORY/HEATER BLOWER 1 BLUE/RED (+) IGNITON SWITCH HARNESS
any of those will work
80Truck
Oct 12, 2025 07:25 PM
okamikai
Apr 30, 2018 10:19 PM
TDonkey
Jul 26, 2015 10:14 AM
Johntom240
7
Jul 13, 2015 12:18 AM
colinmil
Jul 6, 2015 04:03 PM
