General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
In cab winch controls
Old Jan 25, 2007 | 07:04 PM
Albuquerque Jim's Avatar
I would like to wire my M8000 to work from in the cab without my controller.
I found this write up and I just want to make sure it will work fine. I thought this set up would require a relay.
Is this wiring diagram ok?
http://www.webejeepin.com/images/Gle...h-switches.jpg
Old Jan 25, 2007 | 08:38 PM
reggie 00's Avatar
I an pretty bad with car electronics so i didn't look.
But RobinHood did a in car set up using mirror controls from a newer 4runner that worked out pretty good. There is a pretty good write up on it in here somewhere (couldnt find my bookmark)
Old Jan 25, 2007 | 08:43 PM
Elton's Avatar
https://www.yotatech.com/forums/f129/cab-winch-control-3rd-gen-toyota-4runner-using-oem-power-mirror-switch-75327/ ?
Old Jan 25, 2007 | 08:48 PM
AxleIke's Avatar
If that doesn't work, check out
http://www.12voltguy.com/catalog.0.html10.0.html
Great customer service, and cool products
Old Jan 25, 2007 | 08:57 PM
Thanks, since the diagram I linked to was the basis for the mirror switch controller I should be fine.
Old Jan 25, 2007 | 11:32 PM
Flygtenstein's Avatar
My XP had a flipping ground that meant that diagram would not work.
I have not done the install on anything other than mine though.
Old Jan 26, 2007 | 12:15 AM
Corey's Avatar
Co-Founder/Administrator
I have an incab/outcab/anywhere I wanna be
I used this on the 4Runner, and it is now wired up on the FJ Cruiser.
http://www.ramsey.com/accessories_wireless.html
There is a 3 MB video at the above link too.
http://www.ramsey.com/press/features-wireless.html
http://www.rockcrawler.com/techrepor...9500/page5.asp
Install guide PDF
It works really good, and the cool part is you can use it in or out of the rig.
Works upto 100' away too.
Old Jan 26, 2007 | 07:53 AM
Bighead's Avatar
Another option from Roadless Gear: Dash mounted winch control
Old Jan 26, 2007 | 08:04 AM
Corey's Avatar
That is a nice looking one, along with the one by the 12volt guy.
Old Jan 26, 2007 | 08:47 AM
Roadrunner's Avatar
I've got the Roadless Gear one too, a neat little mod.
Old Jan 26, 2007 | 09:05 AM
SteveO's Avatar
Don't know if that particular one would work, but I have winch in-cab controls with a safety switch and a rocker arm switch that controls the in/out relays. I've been using it for some time now, no problems.
Old Jan 26, 2007 | 09:08 AM
WATRD's Avatar
Third! I mounted mine in the cubby beneath the single din radio, next to the dual battery control/status.
88sasturbotoy
Jan 30, 2026 01:57 PM
JAMGarcia
7
Jul 31, 2015 11:46 PM
kirkrunner
Jul 27, 2015 07:59 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
Vargntucson
Jul 4, 2015 12:15 PM
