General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Hot Main Fuse
Old Jul 24, 2006 | 12:36 AM
islandTOY's Avatar
Hot Main Fuse
I was wondering if anyone knows if the main fuse (EFI main fuse) are suppose to run real hot. I notices that the main fuse on my 86 4wd gets real hot while the engine is running, I was wondering if this is normal?
Also, I am having headlight problems, both high and low beam doesn't work. only parking, turn signal lights are working. I checked the headlight relay, the light dimmer switch and the light switch and they all seem to ohm out as specified on the toyota repair manual. But the headlights do not turn on. sometimes it does but most of the time it doesn't. There is something I noticed while trying to trouble shoot the wiring... the fuse box in the engine compartment there is a plug right below the headlight relay and fuses with only three wires. with the light turned to on without the plug inserted I get a voltage measurement of around 12V or higher. When the plug is inserted I only get a very low reading of about 1V. When the light does work I get a 12V reading from this plug. Does anyone have an idea why this is?
thanks!
Old Jul 24, 2006 | 02:48 PM
islandTOY's Avatar
Just wanted to correct myself.. it's not the main fuse that is getting hot, it's the main relay..
Old Jul 25, 2006 | 04:52 PM
Elton's Avatar
i dont think it should get hot just a little warm
80Truck
Oct 12, 2025 07:25 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
stock87yota
Jul 31, 2015 10:08 AM
rushw
Jul 18, 2015 01:46 PM
the1998sr5
Jul 16, 2015 06:20 AM
