1985 Power window/door lock conversion
Hello, I have a 1985 Toyota RV 22r/4speed. I am restoring it, and I am going to install factory power window/door locks in it from a 1988 4runner...I also have the door panels, switches and the 2 20 amp circuit breakers etc..I was wondering if anyone has done this before and can direct me or tell me which wires are 12V vs ground..the master switch has 8 wires going to it of various color...5 wires coming from the door lock/PW circuit breakers..any help would be appreciated, Thanks, Dave
He said he took the complete door harness from the donor truck and installed it in his. Then the plugs wouldn't fit so he had to swap dash harnesses. It's a good thing he had the junked truck to use parts off of. I'll look in my info for a diagram/colors for the switches. I think it (wiring info) only goes back to 1990.
Have you looked in a Haynes/Chilton for a harness diagram?
pw/pdl conversion
Havent tried Haynes/Chilton..typically those manuals are useless. If I knew the power/continuity/ground of the wires at the master switch ( if his has pdl too), that would put me in the direction I need, Thanks for your time, Dave.
Jun 1, 2021 01:51 PM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
Aug 4, 2015 02:08 PM
Johntom240
7
Jul 13, 2015 12:18 AM
