General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
a/c lights
Old Sep 6, 2006 | 07:32 PM
traben27's Avatar
a/c lights
the lights above the cd player (the a/c lights and all that) in my 94 4runner only come on at random times and i cant figure out why. any ideas?
Old Sep 7, 2006 | 12:58 PM
freshman's Avatar
it could be a loose bulb. Remove the a/c or heater faceplate, remove the clear thick plastic cover and you will se the small bulb with green rubber cover. Check for proper fitting.
Old Sep 7, 2006 | 03:32 PM
traben27's Avatar
thanks i'll try that
Old Sep 7, 2006 | 03:45 PM
seanz0rz's Avatar
Guest
have the same problem in my 98. the light above the fan speed slider goes out. if i tap it it comes back on, but it seems to be more tempremental now, requiring me to beat it to come on, if it does at all, i guess i should check for a loose connection. btw, the bulb, if burnt out, is like 6 bucks for 1. just FYI.
Old Sep 8, 2006 | 09:15 PM
traben27's Avatar
okay well i took all the stuff of and got to the bulb, but i dont see how it could be loose, so i tried to fix it but it didnt work.
Old Sep 8, 2006 | 10:30 PM
Elton's Avatar
check the plug and the bulbs that should work
mussy01
Dec 13, 2016 08:20 PM
AkitaDog
Sep 1, 2015 08:05 AM
stock87yota
Jul 31, 2015 10:08 AM
jackiebrownia
Jul 20, 2015 09:02 AM
bryan34w
Jul 6, 2015 05:53 PM
