locating the dome light wire
i was wondering where the dome light wire could be located, i.e. which a pillar does it run down. just so im not ripping out all my intrior panels looking for one wire...
thanks
thanks
sorry it is an 89 pickup, and i wanted to splice in led's or some other low power bulb and mount them in the step wells so when the door is opened i get a little better lighting because the dome light is not cutting it anymore...let me know what you guys think. maybe the location of it by the step wells if it runs by there.
at least your dome still works......I have no idea what to do about mine. I know the bulb isn't blown but that is about it. I like the idea of putting lights down there, but I'd be afraid they'd get broken........or wet.
I've no idea if this'll light those lamps if you turn on the domelight at the switch, but that doesn't seem like that's what you want to do..
Anyways, that should work!
The switch on my domelight is going bad and sometimes it won't work. Shouldn't be too much to take it apart and clean it out with some electrical contact cleaner. Have you tried that?
so im thinking of following the dome light wire to the floor of the rig and just splice into it there that way if i want the lights off or on constantly i can do so, by using the dome light as a switch...would this work?
ashersullivan88yota
Jan 18, 2022 05:37 PM
Johntom240
7
Jul 13, 2015 12:18 AM
