PDA
View Full Version : General Electrical & Lighting Related Topics
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13
  1. 1986 pickup
  2. 2015 4unner flashing 4x4 lights, ABS light and traction lights
  3. 1989 3.0 Pickup Alternator Wiring Issue
  4. srarter relay, pins 30 and 87
  5. connecting after market starter relay
  6. 3vze isolated yellow wire with blue stripe coming at a fuel rail what's it for where
  7. wiper switch question
  8. 1984 no low beams only high beams work
  9. Gen 4 tailgate connector
  10. 2004 4runner airbag impact sensor wiring
  11. Air Flow Meter Fix (a suggestion)
  12. 1988 4runner keeps dying
  13. windshield heated element connection
  14. Wiring igniter in
  15. Where all does small red IG alternator wire go to?
  16. Help with low reading on alternator IG and L wires
  17. ECU test procedure
  18. 2012 4runner sr5 master power window wiring
  19. New alternator but unsure which pin to use.
  20. Hilux Surf Field Monitor installed in a 3rd Gen 4runner wiring help
  21. Re wiring 4wd indicator light after sas
  22. Unknown Interior plug ports
  23. Actuator Mystery! Locks but does not unlock unless it is warm outside
  24. 1989 Pickup sometimes stumbles, lacks power, or stalls when cold
  25. 22re harness problems
  26. Need help with kill switch installation to COR 95 22re base
  27. Best LED headlights for the money on a 1990s Toyota truck?
  28. Clutch start cancel question
  29. 05 sienna rear hatch door ajar light
  30. Unusual electrical issue
  31. Rear window key switch troubleshooting - 1st Gen (1986) 4Runner
  32. 87 Pickup Instrument cluster help
  33. 20r runs for a little then dies
  34. 1983 4WD truck Charging Woes
  35. 1990 high beam indicator
  36. SUMMER SALE | 20% OFF Select Lighting Products | 7/1-7/8
  37. Solved non-working tach
  38. 2000 4runner limited dash power lose while driving
  39. ID on loose wiring near transmission 22RTE
  40. 1983 wiring loose-ends
  41. 95 Pickup 2wd Blinker Connector
  42. Charging Lamp relay
  43. 1980 sr5 tach issues
  44. 1980 sr5 tach issues
  45. 94' Pickup Base 2wd horn/ac/front blinkers no worky
  46. 90 Pickup - No Low Beams, Only High Beams Work
  47. IS it possible ??Injector related
  48. 94 toyota pickup, 4x4 Manuel
  49. Rear leaf spring markings
  50. 85 4Runner alternator upgrade??
  51. Tail light fuse blowing
  52. '01 Rav4 DIY Headlight Wiring Harness
  53. Field Monitor Unit from a Surf into an LN165 Hilux - help!
  54. Efi fuse issue
  55. 1986 02 Sensor Shielding question
  56. Unknown 22r Electrical Plugs
  57. Code 340 CamSensor circuit question.
  58. No dash lights and need help identifying dash switch - 1993 Toyota Pickup (Hilux)
  59. TPS Sensor , 4 wires to 3
  60. 1994 toyota dlx 4x4 3.0 dash wiring diagram and grounds
  61. Tail lights not working but brake lights are working
  62. Heater A/C console light panel has failed - help
  63. ODB1 error 21 can't be cleared
  64. 84 Pickup Horn Wire Gauge
  65. LED Headlight issue
  66. Turn signal issues
  67. H4 LED bulb problem
  68. 89 3VZE SR5. Pinouts.
  69. 1993 4Runner speedometer
  70. How to trace wire for 4wd indicator?
  71. Horn inoperative
  72. Battery Cables
  73. '93 Truck Headlight Issue.
  74. Heating control stuck so heat won’t come out of vents
  75. 89’ 22RE: No continuity on FPU wire from ecm harness to FPU VSV connector
  76. 88 pickup High beams turning on uncommanded
  77. Need recommendations for aftermarket gauges
  78. Lights acting funky after hitting pothole
  79. No crank no start .. surely it’s this wire
  80. Factory Alarm goes off sporadically
  81. OEM vs AM Knock Sensor 3vze - survey and advice
  82. Hardwire A/C
  83. 4th vacuum switching valve
  84. 12v PROBLEM!! STUMPED PLEASE HELP!!
  85. 91 4Runner spark plug question..
  86. More "Where does this wire go?" '88 22-RE 4wd
  87. '96 t100 Driver Blinker and Dash lights
  88. Really bizarre charging issue, any electrical experts?
  89. 86 22RE where does this wire go?
  90. Side marker lamp assemblies
  91. Inclinometer wiring
  92. 92 Toyota pickup - No tail lights, but brake/dash lights still work
  93. Which Wiring Harness to buy to re-pin, 98 tacoma
  94. 88 Pickup Dome light works when it feels like jt
  95. I don't understand, CA, ECM 85 pickup
  96. Oil pressure gauge and alternator guage not working
  97. My passenger door won’t lock/unlock with the other power locks
  98. How to hook 2L diesel up to stock 86’ 4Runner tachometer
  99. Zombie Light
  100. Ignition and alternator wiring
  101. 98 T100 no Headlights
  102. Best LED/HID bulbs
  103. relay question
  104. fix alternator noise?
  105. Electrical Mishap might help someone.
  106. 1990 toyota 22re pickup
  107. 1990 toyota 22re pickup
  108. New Vendor - Sharing a recent personal build we did
  109. Bad Alternator? 11V on L terminal
  110. 1980 4x4 Pickup not making power
  111. 2019 TRD ORP Blinking Slip Indicator & Multi-terrain select indicator warning lights
  112. Just FYI Tread
  113. Electrical diagrams '82 toyota bj42
  114. Best sealed beam lights for 84-88?
  115. Headlights Not Working on my 88 4Runner
  116. 97 Toyo T100 Headlights on but Noone home...
  117. Help with TPS wiring?
  118. Electrical Codes
  119. 1990 Toyota Pickup Dash electrical Gremlins
  120. Electrical Problem 89 Toyota P/U
  121. 94 4 runner rear speaker wire pin out
  122. 1981 BJ42 Wiring diagrams..?
  123. 83 Alternator
  124. 2018 Factory Battery already Bad?
  125. temp sensor wiring help
  126. 91 pickup running light relay
  127. 94 Pickup Reverse Light Wire Color/Location In Dash
  128. brake/tail/reverse lights off ecu or switch?
  129. 2000 4Runner Headlights
  130. Need help
  131. UZZ31 Won't crank. Dash turns off when key turned to crank.
  132. 4WD indicator light switch repair
  133. Front turn signal conversion
  134. Cluster swap issues
  135. Ignition switch wiring
  136. additional dash rocker switches
  137. 81 pickup running lights/brake light issue
  138. 93 land cruiser instrument pinout?
  139. Dash lights
  140. 3.0 body harness to 22re engine harness?
  141. Erratic Temp Gauge fix
  142. 4Runner wiring help needed
  143. 4runner gen 3 blowing blinker fuses only when activating left side blinker
  144. MSD 6a problems with 22R
  145. 2004 Tundra DRL on/off mod
  146. No Spark but Cranks
  147. Help voltage drop?
  148. Best non-OBD II 3G GPS tracking device
  149. Need help
  150. Speedometer stop working
  151. Rear deck window
  152. Is there a QUALITY aftermarket LED bar that’s AFFORDABLE?
  153. Help with lights
  154. Seat Recalibration
  155. Help
  156. 78 hilux fuel pump not turning on
  157. 86-87 Tail light pin out
  158. Toyota plug and play flat 4/5 wire trailer harness?
  159. sent My 91 toyota and now it won’t start
  160. 94 pickup RAIN electrical short
  161. Wiper and washer stops working then starts working
  162. Alternator wiring/fusing 22RE
  163. Erratic starting issue '94 4runner
  164. Loose wires under dash on '85 22RE w/ 5 speed swap
  165. 1987 rear window stuck open
  166. 90 4Runner throttlebody 3VZE
  167. 1980 Toyota Pickup Turn Signals Not Flashing
  168. Toyota 1KZ-TE wiring diagram
  169. 82 pickup wiring connectors
  170. Charge light on then off
  171. Burning 10 gauge fuse
  172. Airbag light is on - code is 31 -T100
  173. Where are '86 4runner turn signal fuses?
  174. 3rd Gen fog lights not working
  175. 2nd gen headlights keep burning out.
  176. Parasitic Drain in Van
  177. Installed new ignition cylinder - no start.
  178. 22R-E O2 sensor woes
  179. headlight
  180. Melted fuse slot..3rd Gen pickup
  181. Temp Sender?
  182. LED guages backlight conversion.
  183. Need Help With Wire Color Codes
  184. Headlight Buckets
  185. Running 24v on a 12v truck
  186. Brake light & Battery light stays on in cluster!
  187. 3vze no crank
  188. 1991 Pickup Dead
  189. Low beams not working
  190. Alternator parasitic draw
  191. Help! Went mudding now no charge
  192. No Start
  193. Instructions to Mechanic to Get Daytime Running Lights (DRL) on 1995 Pickup
  194. 83 pickup wiring HELP
  195. 1994 Toyota Pickup 4X4 Instrument cluster light & socket size.
  196. Timing Light
  197. 82 Toyota Pickup turn signals blinking fast
  198. 95 3VZE temp guage drops when cabin blower switched on
  199. Starter Spins But Won't Engage
  200. 1992 Connector Idenification
  201. broken wire igniter connector
  202. 86 Toyota pickup poor headlight lighting
  203. 87 4Runner won’t start, flasher relay buzzing
  204. Wiring harness
  205. 92 Toyota pick up reverse light issue 3.0
  206. Used ECM swap on a 95 pickup V6 3.0? Reprogram or No?
  207. where do i get a 22r alternator static condenser
  208. Anyone here good at building megasquirts for 22RE
  209. 1991 toyota dlx pickup with 3.0 running light issue
  210. 1987 22r Pickup fuel gauge problems
  211. 2013 Land Cruiser LC200 (American) whirring noise behind NAV
  212. Daytime Running Lights - DRL - LED Conversion
  213. Ditch lights?
  214. SR5 Oil Gauge Repair
  215. First Gen Headlight cage / chip guard - part #? Where to find?
  216. Keep blowing 15a fuse 1992 pickup
  217. Buzzing relay when using right turn signal.
  218. SiriusXM Antenna. What Do You Use?
  219. Custom Instrument Cluster lights
  220. Alternator/Regulator /Charging issue
  221. 93 Toyota 4runner v6
  222. KC HiLites Covers on Hella Lights?
  223. autometer install
  224. Ecm
  225. Efi
  226. Gauges and Climate Control Not Working...
  227. Dome light not working
  228. Charge light, Brake light and green turbo light come on when it revs up
  229. 4r2007 lro
  230. Sending Unit Repair for 78-89 Toyotas $5
  231. NO power to system
  232. Factory amp
  233. 1987 Toytoa Pickup electrical questions
  234. Few electrical questions
  235. Turns over real slow.
  236. Turns over real slow.
  237. 1991 4runner 3.0 v 6 no start or lights
  238. Replaced master switch and windows will still not work
  239. HELP '85 22r [CARB] no start with ignition switch...BUT...
  240. I screwed up! Fuel System Wiring
  241. Electrical problems after arcing positive terminal
  242. Anatomy and Repair of a Toyota Combo Switch
  243. Power antenna timer?
  244. Side marker lights not working
  245. 98 4runner power antenna motor relay
  246. new fuse box
  247. Starter Short Blunder...HELP!
  248. brake light issues
  249. 2007 Tundra SR5 Interior lights inoperative and interior clock resets to 1:00
  250. sr5 guage cluster swap problems.
