General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
brake light issues
Old May 6, 2018 | 10:28 AM
skemp's Avatar
brake light issues
1977 pickup tail lights break lights work step on break rear right lights go out???? Have replaced the bulbs and break light switch cleaned grounds checked for corroded tubes
Old May 6, 2018 | 06:19 PM
RAD4Runner's Avatar
A problem well-stated is almost solved... Please put us next to your truck so we can help troubleshoot from thousands of miles away.
Originally Posted by skemp
... step on break rear right lights go out...
1) ALL rear lights go out? or
2) BRAKE lights come on but all TAIL lights go out?
What happens when you use left turn signal?
What happens when you use right turn signal?
What happens when you use hazards?
How did you clean grounds? how clean did you get them? Where are the grounds?
Double-check your connections, light sockets, wiring. Connections should be bare, shiny metal making tight contact with bare, shiny metal. Anything short of that is no good.
Turboz
Oct 9, 2017 01:33 PM
Baileykl
Apr 23, 2017 12:14 PM
bulldawg901
Mar 23, 2017 06:36 PM
Mack
7
Jul 16, 2002 06:46 PM
