General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
'93 Truck Headlight Issue.
Old Oct 8, 2022 | 12:06 AM
XJ_Guy_In_Yota_Forum's Avatar
Angry '93 Truck Headlight Issue.
High beams in this truck never worked. ('93 Truck, 3.0 5sp) Went to install new LED headlights and ran into a problem.
After hooking them up and testing them, we only had brights. We could flash the brights and toggle them on but no low beams. We checked fuses and relays and they were good. Started tearing stuff apart to get to the wiring around the steering column and the harness there and check connections but I'm pretty stumped on what it could be.
Old Oct 8, 2022 | 11:01 AM
2ToyGuy's Avatar
Check the way the new LEDs are wired in. Sounds like the low beam side isn't connected to the wiring correctly. It could also be that the Toyota system is switched ground, and USUALLY, LEDs are switched hot. Could the switching be in error? In the LEDs wiring.
Check the stalk on the steering coloumn. It's switch contacts are right out in the open. Sometimes the little brass arms the contacts are on get bent over time. Could it be the low beam contacts aren't making, or the high beam contacts are constantly making? Just a possiblility.
Let us know what you find out
Pat☺
JacobMillis
Jul 15, 2021 10:46 AM
4runnerlife24
Jan 3, 2017 06:25 PM
greenbuggy
Jun 15, 2015 05:49 AM
FuelforWar
15
Nov 17, 2011 11:26 AM
starrett
Jul 31, 2007 05:41 PM
