General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
88 pickup High beams turning on uncommanded
Old Jul 27, 2022 | 01:51 AM
Thecpsystem's Avatar
Hey all,
my 88 pickup was stolen a few months ago and didn’t come back in the same shape she left.
the problem I seem to be having is with my headlights.
while driving (Especially turning) my headlights will switch from low to high beam momentarily and my high beam indicator will come on in the dash. It only lasts for 1 or 2 seconds and goes back to norma.
The problem seems to happen with lights on or off.
All I can think of is my harness is finding a ground that it shouldn’t be?
anyone else ever experience this?? Maybe they ripped apart my steering column and messed with some wires? At a glance I can’t see anything wrong but that doesn’t mean it’s not there.
Old Jul 28, 2022 | 01:30 PM
Discombobulated's Avatar
Well if they ripped it apart you would notice? How did they get it to start? What was destroyed?
Old Jul 28, 2022 | 04:59 PM
they put most things back together, just rather sloppily. Incorrect bolts everywhere and lots of electrical issues are the biggest problems.. but nothing too noticeable about my steering column.
my truck is pretty start with any key and they sawed through my steering whee club.
Old Jul 28, 2022 | 05:34 PM
What other electrical issues? If you know what was put back like poo could be related. When you say they was it a shop that put everything back from the damage?
It happens while turning for sure sounds like a column thing, have you taken the column housing off and taken a look see??
Old Aug 4, 2022 | 09:55 AM
Tims86Toy's Avatar
Most likely cause it's the combination switch for your Turn signal/High/Low Beams. Mine would suddenly turn the lights off if I had them on High beam due to a short in the mechanism. There's a small spring and ball contactor at the tip of the switch inside that may need to be cleaned or it may be another wire inside the switch that's loose. See if you can reproduce the problem by wiggling the switch or turning the wheel.
david05111
Jan 25, 2022 05:27 PM
oilfieldmarine
Jul 9, 2018 01:08 PM
goose hunter
May 21, 2014 03:06 PM
Nimrod
7
Sep 26, 2007 04:08 PM
hirsche23
Nov 2, 2006 12:20 PM
