PDA
View Full Version : General Electrical & Lighting Related Topics
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13
  1. new to tacomas plz help
  2. Killed my Optima Yellowtop in a year
  3. Electronic Locker not working
  4. Voltage Problem With Injectors
  5. only brights work
  6. Light Laws in PA
  7. Blowing EFI fuze and hot EFI relay in engine fuze box
  8. Dash lights blinking
  9. Where to place my hella lights. **PICS**
  10. Power Window going down... but not up
  11. problems with automatic door locks
  12. Digital dash question
  13. any one know key ignion swaps
  14. Installing radio.Which is power wire??90 toyo
  15. real nasty yellow substance on connectors in diag box
  16. gage cluster ? back from just dashes
  17. Need help with airbag light issue
  18. I need to install a light into the heat control panel on my 1984 toyota pickup
  19. Oil Pressure Sending Unit Wire Color
  20. 89' Yota- Power windows inop
  21. i turned the key and everything went black...
  22. back window doesnt work
  23. Connector Part Number for sensors on Water Bypass Outlet Housing?
  24. no power to any of my windows
  25. Stuck Key:Where is the Interlock Control Unit
  26. fuel pump relay issues
  27. Can someone identify these lights for me.
  28. Blue Sea Mod.
  29. Determining Wire Required Size
  30. How do I disable my automatic headlights?
  31. 1987 Toyota 4Runner no start
  32. Hella 500's blowing fuses - Please Help
  33. viper alarm system!!Please Help!!
  34. How would I install an aftermarket speedo on my 94?
  35. YIKES. Reversed Polarity on Battery install. HELP.
  36. Clear lenses now available for ARB bumpers!
  37. FLX-210 Fan installed Have a few qs and issues
  38. Right signal light
  39. quick 4runner rear window question
  40. Winch not working, but solenoids click??
  41. fuse box help
  42. Converted my Hella 500's to HID's
  43. 91 4runner Wiring harness
  44. HIDs and LEDs Installed!!
  45. No high beams - no bright lights
  46. Absolutely No Power
  47. wet weather blues
  48. Help me "Frankenstine" some Aux. lights
  49. LED Lights for the gauges and under the seats of the driver/passenger
  50. aux lights wiring problems
  51. Stock Parking Lamp is 5W - PIAA W2 is 18W but fits, Is this okay?
  52. No Low beams
  53. Viper Alarm + Factory Horn
  54. Where do yall mount your auxillary switches?
  55. 1st gen 4runner taillight problem
  56. Tailgate defroster wiring harness
  57. 6pin to 4 pin taillight converter for towing
  58. Igniter/coil assembly problems in '83 pickup
  59. pwr door locks got me stumped
  60. HID Conversion Problem HELP!!!
  61. Burnt parking light effecting trailer lighting
  62. 1999 4Runner Guage Cluster/AC/Gear Shift bulb sizes?
  63. air intsake female plug end and its connecting pins
  64. Help on 2001 prerunner lights
  65. '98 4Runner - Elec Prob - Rear Brake Lights Out
  66. 88 rear window problems
  67. Stock radio with aux input?
  68. brighter parking lights on the cheap
  69. Need help 86 4runner acessory always hot
  70. starter wiring question 22 re
  71. HELP~~~>>>What does the Knock Sensor do...???
  72. Tail light: No brake light. Signal and parking work
  73. power inverter help
  74. O2 sensor wiring....HELP
  75. Toyota 3vze 3.0l v6 engine hi-pro 190hp/210ftlbs
  76. 85 4runner fuel pump
  77. '06 4Runner Alternator Capacity
  78. 93 Toyota under the EFI where does this wire lug go?
  79. Momentary loss of all electrical while driving
  80. LED Guage Light Install How-To
  81. Help should i buy these piaa for $100
  82. Battery/Charge Indicator Light Not Working
  83. fuse panel
  84. 1990 Toyota Truck Engine Harness?
  85. Fuse For Center Console Switch for Rear Window???
  86. Alternator issues?
  87. 1990 Toyota pickup Headlight issues
  88. 89 yota pickup Highbeams don't work.
  89. hitch wiring problem 91 surf
  90. help!!!! 84 pick up alternator connecter
  91. 2000 land cruiser flasher relay location?
  92. Tail lights stay on when key is out
  93. 2004 with Check Engine and VSC TRAC/OFF lights on
  94. Installing Back-up lights?
  95. My thoughts on HID Lighting
  96. crazy lites
  97. A/C fan clutch wiring
  98. Minumum needed to power starter
  99. Transplant wiring issue
  100. Which lights?
  101. daytime running lights
  102. toyota 4 runner rear window
  103. tail light wiring , oo to 02 mod
  104. Changing/upgrading spkr wires
  105. Need info on O2 wiring '96 4R(someone stole my cat...)
  106. radio help!!!!
  107. Ignition woes..
  108. Charge light problem
  109. Battery question
  110. Rocker switches
  111. About to run it off a cliff
  112. Anyone have LED driving/fog lights?
  113. Tail light and Dash Lights
  114. Air Cond Comp clutch fuse
  115. need help w/off road lights and relay
  116. Pulsing Lights
  117. Slow rear door windows
  118. fj cruiser trailer lights convertor box
  119. Aux. Fuse Box Questions
  120. Need Help Broke this wire on my 99 4runnner
  121. CD Player sometimes turns off after bumps?
  122. 3rd Gen aftermarket speakers
  123. Hitch-mounted backup lights?
  124. 1988 4 runner dash harness
  125. Front Parking lights won't come on.
  126. bulbs were rearview mirror is mounted. Plus a nasty story!
  127. oem foglights anyone used these?
  128. 85 to 88 wire harness swap help!!!??
  129. Mirror Defrosters
  130. heater control
  131. '94 4runner tailgate issues - auto roll down as soon as the ignition is on???????????
  132. Will this switch fit in my dash?
  133. brake problem
  134. truck cutting off
  135. Infamous Rear Window
  136. Tail light wiring .HELP!!
  137. Anyone know the electric fan math at DCC site?
  138. hella micro de fogs
  139. rear hatch sensor
  140. I'm NOT seeing blue! Blue LED's that is :(
  141. Silverstar Headlights
  142. rear window quit on me - 89 4runner
  143. Remote wire 4 87 4runner
  144. Taillight and blinker problems 02 runner
  145. fuel gauge problem
  146. EFI to carb swap
  147. Need help with after market stereo wiring!
  148. Left side of trip computer is dark
  149. '76 pulsing headlights & swinging ammeter - pic
  150. Ok Let me get this straight....
  151. body swapping questions
  152. many accessories, external battery post?
  153. Rev Knob under glove box?
  154. big electrical problem
  155. Possible short?
  156. Need Bulb #'s For 2000 LTD 4Runner Interior LED's
  157. speedometer and ac lights not working
  158. Head lights
  159. which ecm will work
  160. idiot lights in dash stay on
  161. LED dash light voltage issue?
  162. heater controls and shifter lights burnt out!
  163. Deck Lamp Switch?
  164. new brake wiring harness for 85' 4x ...(?)
  165. 98 tacoma tail light and blinker
  166. 2002 4 runner
  167. New alt. new battery, still having problems
  168. Sub Box Placement
  169. O/D light question
  170. No Altenator light
  171. Intermitent Blower Fan
  172. multi batteries and isolators ?s
  173. Best foglight/driving light for reasonable $$$$$$$$
  174. Turn Signals Wont Work
  175. Removing Headunit
  176. heater resistor location?
  177. aux lighting, big 3 upgrade questions..
  178. tail lights not working please help...
  179. cd player help
  180. Alternater help
  181. 99 4runner ignition ring light not working
  182. heater fan switch melt down
  183. won't start
  184. 90 Cab 94 22re wiring help
  185. Which is power wire?
  186. cig lighter power problem need help
  187. quick question about drl
  188. Low beams not working - '96 Tacoma
  189. Headlights
  190. Rear window motor help
  191. Reverse lights not working
  192. Clear up Grounding Question?
  193. Very dim illumination on stock radio buttons
  194. ABS/Brake/VSC Trac light on - shop unplugged something
  195. Wiring help
  196. Fuse panels on 94 4runner?
  197. Parking/dash lights will not turn off.
  198. power locks
  199. 2nd gen battery tie downs
  200. Installing 40 Year Old Lights (no ground wire)
  201. engine light constant flash!!
  202. head lights
  203. need ideas that work
  204. WTF? is that noise
  205. Driving light - Looking for eyelids
  206. turn signal come on when brake pushed, Help!
  207. Sequoia rear HVAC controls question?
  208. Please Help Windows not working
  209. grey wire mod?? Bad link...
  210. Turn Signals!!
  211. 88 4runner dash lights not working
  212. Whats the difference between 55w-150w
  213. what do i need to upgrade?
  214. rear window console switch
  215. how to
  216. 3rd Gen 4RuNnER Radio Fuse??
  217. How do you read a wiring diagram?
  218. Electrical problems - no spark
  219. 1988 4runner fuse and motor questions
  220. Help on toggle switch
  221. injector problem
  222. power windows dont work
  223. knock sensor wire color?
  224. Headlight ??
  225. 22re - Starter click and faint electrical squeal
  226. wet starters and solenoids
  227. Stock 01 taco stereo/sub box build
  228. 97 4runner full-time power mod help...
  229. Help with ignition questions
  230. Which Optima to get?
  231. My brights will not turn on
  232. electrical porblems
  233. PIAA quattro question?
  234. Need To Jump Start Everytime After Sitting For Week
  235. Toyota OEM Style On/Off Rocker Switch
  236. 1998 4 runner battery dies if engine not started
  237. 22re ecu pinout 94 Toyota pickup
  238. Couple of newb questions about electical functions with no key
  239. Help with check engine light???
  240. Wiring reverse lights
  241. Lets see how bright your lights are at night
  242. 2nd Gen Reverse Lights
  243. delco cs144 conversion problem
  244. New Stereo = No Locker?
  245. issues and surprises
  246. making a wiring harness
  247. Tail lights blowing fuzes?
  248. blinkers and hazards just died
  249. hella 500 issues
  250. Couple quick harness questions.
