General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
wet starters and solenoids
Old Nov 28, 2008 | 11:21 PM
buel09's Avatar
have any of you had problems with your starters or solenoids after they get wet, this is the third starter in a year i had to replace, i think rust and corrosion is the culprit ?, is it some way to stop it from getting wet like electric grease or something. thanks.
Old Nov 29, 2008 | 01:36 PM
4Crawler's Avatar
What exactly is going out on the starters? I've never had a problem with the stock Denso starter on my '85, I think it is original. Has been under water a more than a few times over the years.
Old Nov 30, 2008 | 11:46 AM
buel09's Avatar
i open the starter solenoid and it looks like it's ben in the ocean for 7 years, i'll say corrosion is a understatement, water have been coming in a vent on the side and not going out
Old Nov 30, 2008 | 11:49 AM
Burntricer's Avatar
ive had my starter freeze up on me a couple times, shes all good now, but it was really stuck a couple weeks ago
Old Nov 30, 2008 | 11:55 AM
4Crawler's Avatar
At least on the OEM (Denso) starters, there is a drain tube on the bottom side of the solenoid to let any water that does get in drain out. If yours has a drain tube, make sure it is not clogged and if no drain, consider getting a used Denso starter from a junkyard and swap that in.
Old Dec 1, 2008 | 01:07 AM
buel09's Avatar
solenoid contacts
In the morning i'm dropping by toyota and picking up solenoid contacts
ladybugRC
458
Aug 21, 2020 10:41 AM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
puddlepirate
Sep 29, 2015 08:02 PM
Odin
Sep 26, 2015 06:56 PM
