General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Tail light wiring .HELP!!
Old Feb 11, 2009 | 11:16 AM
bipolarandproud's Avatar
Can anyone tell me where the green and red tail light wire runs to ? I haven't had the tail lights working for awhile .So I've been trying to figure it out when I had the time . First I checked for power at the tail light with the light switch on then with a mulitmeter ,I probed the same wire near the fuse box with the switch turned on.It doesn't get any voltage either .After I do that I lose the wire when it continues under the dash . Does the wire go directly to the combination switch or where does it go ?
Old Feb 11, 2009 | 12:00 PM
BUmp**
Old Feb 11, 2009 | 06:28 PM
eric-the-red's Avatar
Might help if you let us know what year and whether it's a 4Runner or truck. They all have different wiring colours. On 2nd and 3rd gen 4Runners the tail lights are controlled by the tail light relay, which is in turn controlled by the switch. On those the green wire won't be live until the relay is triggered. The fuse is after the relay so that also has no power until the relay is on.
Old Feb 11, 2009 | 08:19 PM
Dam ! Sorry about that , I keep forgetting to add the year and model .
It's a 1987, 4runner ,22re Thanks for the Tips tho !
Old Jul 5, 2012 | 11:11 AM
37mountainguy's Avatar
My tail lights and dash lights went out. When I went under the steering wheel to find the fuse box I found a relay that was not attached to anything and fell out of all the wires. I'm thinking this is the problem. But I can't figure out where it goes. Help?
Old Jul 5, 2012 | 01:42 PM
Hadmatt54's Avatar
If your 87 4Runner is the same as the 86, the only red wire in the taillight circuit is 12v from the tailight relay to the source side of the 15a taillight fuse. A green wire leaves the fuse and goes to the tail lights.
Old Jul 6, 2012 | 11:34 AM
mine is a 95
Old Jul 6, 2012 | 11:41 AM
my problem solved. It pugs in to a socket just about the fuses on the right side of the box in case anyone else has that problem. It fixed everything. Back to normal.
Sleaker
Aug 26, 2020 06:03 AM
Sep 4, 2015 09:27 AM
sabine
Jul 18, 2015 03:59 PM
88yodabasket
Jul 13, 2015 01:32 PM
Johntom240
7
Jul 13, 2015 12:18 AM
