General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Which Optima to get?
Old Nov 24, 2008 | 11:08 AM
michalik_piotr's Avatar
I think there are three, red, yellow and blue? I plan on running an amp and getting a winch. I also have a set of Hella 500s and on wknd surft trips run the stereo and lights with the truck off quite a bit. Thanks
Old Nov 24, 2008 | 11:16 AM
i think i just answered my own question. now, how long can you run a stereo with say a 100 watt amp off your yellow top and then still be able to start your truck?
Old Nov 24, 2008 | 11:25 AM
GSGALLANT's Avatar
Depend on the reserve capacity of the yellow top (there are different ones). As an example, a good estimate of how long a 120 Amp-hour reserve battery will last if you have 100W radio + 100W lights going is:
200W/12V= approx 16 Amps
120 Amp-hour/16 Amps = 7.5 hours (This is approximate, because voltage drop will not be linear...)
That, I assume is to get your battery "dead", which will be something like 10 or 10.5 volts, which probably won't start your vehicle.
The best solution is to have a dual battery setup.
Old Nov 24, 2008 | 11:57 AM
trbizwiz's Avatar
The yellow toppers run about $160 at sams club. A dual set up will be costly.
Old Nov 24, 2008 | 12:03 PM
i found them for $249 at summit. theres two diff ones that look identical and i'm not sure what the "group/bci" number is as that is the only diff.
Old Nov 24, 2008 | 12:09 PM
trbizwiz's Avatar
https://www.yotatech.com/forums/f123.../#post50404952
Old Nov 24, 2008 | 12:44 PM
hross14's Avatar
I have the oddyssey PC 1700. And here is what i think--its big and has alot of reserve--so it is a poor mans two battery set-up with a push start just in case (Manual Tranny)
george16
11
Aug 24, 2005 01:31 PM
WT
Jul 1, 2004 05:24 PM
shazaam
10
Apr 16, 2004 11:03 AM
Bob K
Jul 22, 2003 03:01 AM
Los Gatos?
25
Apr 18, 2003 08:00 PM
