General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Head lights
Old Jan 27, 2009 | 02:21 PM
86yota2wd's Avatar
Head lights
I was wondering what the brightest replacement headlights you can get for a 1986 toyota pickup and is it possible to put fog lights on the front bumper where the bolts on top are and if so what kind?
Old Jan 27, 2009 | 04:01 PM
aviator's Avatar
Fogs up top would not be the best idea since there beam pattern has a very wide spread. You'd be blinding on coming drivers for sure. Driving lights are a better choice for mounting that high. I had a set mounted up there on my old 87. As for what would work just about anything there is a fair bit of room so your choice is just about limitless. I used a pair of $30 hella clones and they worked great, I even used them as headlights a lot of the time and did not even bother with the regulars.
Higher power headlights are available but if you want to stay stock the strongest I've ever come across are 55/65w. However if you switch to an H4 type light you can go all th way up to 100w+ or even HID. There are several mfgs. to choose from here, I went with a Bosch conversion kit that had two replacement lens/housings and bulbs for $90 cdn. They feature a euro spec light spread pattern that focuses the light forward and slightly up to the right to illuminate the curb and road ahead while reducing glare for oncoming drivers. You can also get a Hella kit that features the same pattern but these are only sold in single units that I've seen.
I've used the bosch kit on both my yotas and have been very pleased with them I ran 80/100s in my 87 and never heard a word from any cops about too bright a light. In my 94 I'm running 55/65s since the dang gov't outlawed the sale of the high power bulbs here I have'nt been able to find the others anymore.
ashersullivan88yota
Jan 18, 2022 05:37 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
Odin
Jul 15, 2015 09:28 PM
