General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Which is power wire?
Old Jan 1, 2009 | 12:25 AM
jux's Avatar
jux
I have a third gen 4runner and was wondering which is the power wire for the power outlet? The wires are purple, black, and white. Thanks
Old Jan 1, 2009 | 06:40 AM
tysen86's Avatar
a test light will tell you every time!! hook the clip to a ground and touch the light end to the wires( one at a time) when you find the hot one the light comes on!
Old Jan 2, 2009 | 11:35 AM
schmooot's Avatar
there are 3 wires going to your power outlet? If it was just black and white then white will be hot and black will be ground, in your case purple may be hot but I don't recall seeing a 3 wire power outlet ever.
Unless you somehow have an AC power outlet in your truck...in that case it all depends on who put it in (not sure if toyota ever used factory inverters).
Either way a multimeter is your best friend
Sleaker
Aug 26, 2020 06:03 AM
keithporter83
Jul 24, 2015 07:37 AM
luckypig44
Jul 19, 2015 11:25 AM
Johntom240
7
Jul 13, 2015 12:18 AM
nick b
Jul 11, 2015 04:38 AM
