General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Electrical problems - no spark
Old Dec 5, 2008 | 02:34 AM
cras89's Avatar
Hey everyone,
Last weekend I was working on my car, all I changed were headlights and spark plugs, went to start it up, and nothing, no spark. Coil, igniter, distributor cap, rotor, and fuses are good. Any ideas?
Old Dec 5, 2008 | 02:20 PM
83's Avatar
83
All I can think of is to make absolutely sure you got the right spark plugs, and that every wire is completely "snapped" in on the distributer and coil.
Old Dec 5, 2008 | 11:04 PM
cras89's Avatar
Well, there is no spark getting to the distributor, so it can't be the spark plugs, and I know the wires are on right.
Old Dec 8, 2008 | 06:33 AM
83's Avatar
83
Ok you didn't mention that in your post. So what do you know for sure? More info helps. If you're not getting spark to the distributer, the problem could be the ignitor or ignition coil, but maybe you tested those, and that's why you say they're fine? Internet diagnoses are hard, but even harder when we don't know what you've checked out and done exactly. Does it crank, and just no spark so it won't fire, or is absolutely nothing happening when you turn the key?
If all you did on a vehicle that was working fine before was change the spark plugs and headlights, and now it cranks but won't start, or nothing happens at all, and you know the plugs are the right ones for your truck (part store didn't mess up & give you the wrong ones etc.) and you know all the wires are snapped on completely, then I have no idea what's wrong.
Old Dec 9, 2008 | 10:28 PM
cras89's Avatar
Thanks for the help, I got it figured out, a wiring harness went bad.
Old Dec 10, 2008 | 12:06 PM
83's Avatar
83
How'd you figure that out? Some testers? Glad you got it worked out.
Old Dec 3, 2009 | 01:59 PM
sam6606's Avatar
im having the same problem what wiring harness was the problem
Old Dec 3, 2009 | 02:28 PM
Kiroshu's Avatar
How does a wiring harness just go bad after a tune-up and headlight change.... (kinda funny) sure you bought correct parts....
Old Dec 10, 2009 | 03:56 PM
dubs740's Avatar
My truck also doesn't have any spark now and all I did was clean the spark plugs. its either the distributor or coil that is bad I think b/c i'm getting spark to the coil but from there it goes nowhere. Any ideas? what wiring harness did you switch out?
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
Yota.Jay
Jul 23, 2015 08:08 PM
Sandman
Jul 14, 2015 12:36 PM
karbin
Jul 5, 2015 11:37 PM
