General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
PIAA quattro question?
Old Nov 19, 2008 | 02:24 PM
quickshot's Avatar
hey, i just got my truck back from the shop and now my PIAA quattros turn on when i turn on my regular headlights but its just the white marker bulbs. they wont even turn off when i press the power button on my switch only way they go off is when i turn my headlights on. nor do the main bulbs go on or switch color. what do you think is wrong? thanks
Old Nov 19, 2008 | 02:47 PM
scuba's Avatar
Are the piaa's wired into the lights ?
If so, This could be because the yotas lights are switched grounded, and the piaa's are switched hot.
Im not an electrician, But thats my assumption
Old Nov 19, 2008 | 03:07 PM
quickshot's Avatar
it could be, but the problem is that the two marker bulbs are the only ones on( the smaller less bright bulbs) and when i try to switch the color of bulbs and nothing happens. the bottom mid bulb is the only bulb on, on both lights, while the inside(left) bulb should be on too.
Old Nov 19, 2008 | 03:34 PM
quickshot's Avatar
i just looked and i hear the lights switching, i had someone press the switch for the different modes and i think that the bulbs are loose, so ill check tomarrow when its light out. thanks anyway
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
