General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Power windows! Need advice
Old Oct 27, 2008 | 11:57 PM
74sr5's Avatar
Hi everyone im new here to yota tech...Got a 87 ex cab sr5 manual windows...Im currently doing a power window up grade...Already have power regulars in and power locks and wire harness from a 86 4runner...trying to figure out how to run power to wire harness ...I dont have a relay switch on my truck ... there are six wires running from door to under dash...1 blue w/wht,2 blue w/blck,3 blue w/red,4 white w/blck,5 black w/wht,and 6 solid black wire.. I have FSM of an 85 4ruuner and truck...The color codes from there does'nt match...I think white w/ blck is ground, but the rest I need help with....Any input would be great....Thanks
Old Oct 28, 2008 | 07:39 AM
4Crawler's Avatar
Might be you have a non-relay set of switches (like the '85 and possibly the '86) and have relay wiring in the '87 (not positive when the relay setup was introduced). The '85 FSM shows the non-relay setup where the switches do all the work. In that case, see if you can find out how the wires run between the sides and adapt that to how the switches you have are set up are wired. Pretty much all the wires between the passenger window switch on the driver's side run to the passenger side switch where they are wired in parallel. Either that or find a set of switches and a relay from relay wired truck or 4Runner.
Old Oct 28, 2008 | 03:20 PM
74sr5's Avatar
Thanks 4Crawler.....
Old Nov 4, 2008 | 12:15 AM
idanity's Avatar
i can take pix of mine (currently no door panels) and my passenger side controller was toast...
i know, brown is ground.
i just bought a 2 pole switch and ran direct current to up, and again to down. ground is constant, and the same power goes to both up and down, but on the motor, up/ down is obviously separated
i can take some pix tomarrow...(pm me)
Old Nov 20, 2008 | 09:45 PM
74sr5's Avatar
Power windows are running !!!!!!!!! Mahalo's for all the info and help!
74sr5
Jun 1, 2021 01:51 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
