General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Wiring reverse lights
Old Nov 11, 2008 | 02:58 PM
flashkl's Avatar
I picked up the napa tractor lamps the other day and mounted them as reverse lights, question is do I have to pull a power cord all the way up to the battery? My truck has the trailer wiring harness on it (4 pin), is there a backup light lead on that I can splice into, or is that only for brake light and turn signals? I suppose I could test each of the pins with a voltmeter, but it's cold and dark out, and I'm lazy. Any help is appreciated.
-Kai
Old Nov 11, 2008 | 04:08 PM
flashkl's Avatar
bump bump
Old Nov 11, 2008 | 04:12 PM
littlecommando's Avatar
Try to find the wires that go to the oem backup lights and go off of there
i think, you might blow the fuse tho...
Old Nov 11, 2008 | 04:16 PM
jason191918's Avatar
Wire them directly to the battery and use a relay that is activated from said wire above.
Old Nov 11, 2008 | 04:23 PM
flashkl's Avatar
Well, it's more work, but I guess doing it right the first time is a good thing...
Old Nov 11, 2008 | 10:31 PM
Jay351's Avatar
Yes, just do it right the first time.
Use the proper crimp (or solder!) connectors and wiring loom.
If you need it, here is a general guide to wire up aux lights. Basic, hot setup. Turn them off and on at anytime.
http://img.photobucket.com/albums/v2...gauxlights.jpg
Old Nov 11, 2008 | 10:53 PM
scuba's Avatar
That damn realy !!!
lolz..
Old Nov 12, 2008 | 02:56 AM
flashkl's Avatar
That wiring diagram has... jugs!
Sleaker
Aug 26, 2020 06:03 AM
mengquis
Jul 13, 2015 10:39 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
