General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Installing Back-up lights?
Old Mar 17, 2009 | 07:28 PM
96Tacoma4x4's Avatar
Question Installing Back-up lights?
I'm sure that this has been posted before, but I'm fairly new to the site, so I'm not sure. But anyways, I have a couple of back-up lights that I want to install on the back of my Tacoma, but I'm not exactly sure how I should wire them, for example if I need a fuse or not. I can't and don't want to wire them into the back-up lights because I have a manual, so I want to have a switch in the cab so I can tuen them on and off when I want to. If anybody has a diagram or anything, it'd be great, thanks!
Old Mar 17, 2009 | 08:17 PM
littlecommando's Avatar
did it come with a kit?
if there was a wiring kit with them, just use that
you probaly need to use a fuse for safety
Old Mar 18, 2009 | 12:27 AM
Mtn Mike's Avatar
Yeah a fuse would be good. 15 or 20 amp inline fuse should do it. Also, if your lights didn't come with a relay, search for instructions on using one. The install shouldn't be too tough; mostly just deciding where you want to put everything.
Old Mar 18, 2009 | 01:47 AM
Elton's Avatar
best to use a relay wire it up like this
http://www.4runners.org/image/hella5...auxfusebox.jpg
Old Mar 18, 2009 | 10:07 AM
I had the lights given to me so no, they didn't come with wiring or anything.
Old Mar 18, 2009 | 11:20 AM
eric-the-red's Avatar
So go and buy a relay, an inline fuse, a switch and some wiring and do it right. Shouldn't cost more than $10. An electical fire is much more expensive.
I have mine wired with a relay and also a 2 way switch so I can have them go on automatically with the original reverse lights or just by thenselves with the switch.
Old Jul 25, 2010 | 06:15 AM
pwd's Avatar
pwd
I'm installing some backup lights on my pickup... I've got the wiring all planned, but I'm not sure where to physically run the wire to the back. Do I just run the wire with the frame? I've got the wire coming from under the cab where the other tail-light wires come out of.
Old Jul 25, 2010 | 08:35 AM
Merlin's Avatar
i ran the wires along the frame rails and secured them with a bunch of zip ties. as long as you make any connections good and waterproof, you'll be fine. it's been a couple of years now and they're still okay, and they've gone through all kinds of weather.
Old Jul 25, 2010 | 08:50 AM
pwd's Avatar
pwd
Sounds good, thanks.
Just for future reference... I have read about tapping into the reverse wire so you can trigger something when in reverse (a relay or etc..). I have read that the wire is yellow with a red stripe. That WAS NOT the wire on my 95 pickup, its actually a red wire with blue marks on it. So be sure to do some testing first. I found this out the hard way .
Old Jul 25, 2010 | 09:29 AM
hotrodmkw3's Avatar
I installed a set of backup lights on my rig but the only downside i found was i mounted them on the rear bumber and have knocked them crooked and bent the brackets all up while doing some off-roading but other than that i did the same as Merlin and have hod no issues with piched wires or anything like that, just follow the fuel lines and you'll be safe.
Old Jul 25, 2010 | 04:36 PM
pwd's Avatar
pwd
I followed the wire harness to the taillights, should be O.K. there...except I haven't waterproofed them yet.
I actually cut holes in my bumper, and mounted them inside so I won't knock them off. I'll try and take a couple pics if I do a test drive tonight.
Old Jul 25, 2010 | 04:46 PM
James Dean's Avatar
I did the same thing on my 4Runner. I used LED's so the power draw is next to nothing. I have them connected directly to my reverse wire and I have a switch that can turn them on without being in reverse. Theyr'e not a bright as a KC light, but they work great and look clean.
Old Aug 31, 2010 | 07:37 PM
wentz912's Avatar
can you draw us up a diagram for how you wired it to run the reverse lights off of either the power from reverse or the switch?
raptor510
Feb 17, 2017 07:11 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
Odin
Jul 15, 2015 09:28 PM
