General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
85 4runner fuel pump
Old Mar 28, 2009 | 01:03 PM
toyota rebirth's Avatar
i can get the pump to work with the test plug but when you turn the key it dont come on. tried different ecu still nothing any suggestions.
Old Mar 28, 2009 | 01:32 PM
DYNNOMMYTE's Avatar
have you tried the fuel pump relay?
Old Mar 28, 2009 | 03:29 PM
4Crawler's Avatar
The fuel pump doesn't normally run with the key on, unless you have the test jumper installed:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Only way it runs is if the AFM vane is held open. Test that AFM and if that is OK, then check the circuit opening relay (there is no fuel pump relay, per se).
Old Mar 28, 2009 | 05:39 PM
scuba's Avatar
I have a COR for sale if thats your problem
Old Mar 28, 2009 | 07:06 PM
what is a cor. i checked relay it is efi. it dont even kick on to pressurize the system.
Old Mar 28, 2009 | 09:24 PM
scuba's Avatar
Read the link 4Crawler posted, He knows what's up.
Also,
http://www.personal.utulsa.edu/~nathan-buchanan/93fsm/
http://personal.utulsa.edu/~nathan-b...38circuito.pdf
Have you tried searching...?
Old Mar 29, 2009 | 12:45 PM
thanks for the help. got it figured out. feel kind of dumb didnt have tank in truck ran ground to it and started working.
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
HRDC0R19
Jul 5, 2015 06:43 PM
