General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Slow rear door windows
Old Feb 25, 2009 | 05:58 AM
Birchyboy's Avatar
Slow rear passenger door windows
Both of the rear passenger door power windows on my '93 open/close very slowly, even more slowly when I try to operate both at once. I've tried adding some lube to the tracks to reduce friction without gain. Does anyone have ideas on this other than changing the motors? My only doubt about the motors is that both are working the same, and it doesn't seem like they have been used enough to wear them out.
Thanks!
Last edited by Birchyboy; Feb 25, 2009 at 08:53 AM. Reason: Not the tailgate window!
Old Feb 25, 2009 | 08:23 AM
okie81's Avatar
This post helped me:
https://www.yotatech.com/forums/f16/...-problem-1264/
excerpt from post:
"Biggest cause for older 4Runner rear windows to go slow is a dry window run, dried out grease in the window motor, this all gets thick in colder weather anf a worn gear shaft in the window motor itself, the extra load from dry runs will wear these out quickly, use silicone spray for all your window runs and rubber seal, but dont get silicone spray even close to it if your in primer prepping for paint, the results will make you sick Also, while your trying to roll the window down, look at your dash lights (ie check engine, alt, seat belt, ABS etc), engine off and see if they dim quite a bit, if they do, this is a good indication its getting power to the motor, just hard turning, if they dont dim, it can be other items, most common is the rear wiper park switch, and a latch detection switch, in that order too. "
__________________
Old Feb 25, 2009 | 08:52 AM
Birchyboy's Avatar
Thanks. I should have been more explicit - I'll revise my original post. The issue is with the rear passenger door windows, not the tailgate window.
I'll check the internals for gunk and such, though, just to rule that out.
Thanks!
88sasturbotoy
Jan 30, 2026 01:57 PM
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
icentropy
Jul 14, 2015 10:23 AM
