General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
what do i need to upgrade?
Old Dec 7, 2008 | 06:09 PM
quickshot's Avatar
i have 3 hella black magics ona push bar right now with the 55w bulbs. i want to upgrade to the 100w bulbs. i found the bulbs but will i need to upgrade anything else or is it a plug and play installation?
Old Dec 7, 2008 | 06:50 PM
86autoyota's Avatar
you should just be able to plug em in, just dont touch the bulb itself when installing them
Old Dec 7, 2008 | 06:52 PM
Jay351's Avatar
What guage wiring are you running currently? I would consider going to 14 or 12 guage for your power/ground wires. This would let you get the most amount of power for the new 100w bulbs.
X2, wear gloves when you install them unless you got steady hands.
Old Dec 7, 2008 | 06:59 PM
86autoyota's Avatar
yeah didnt think of the wiring that would be good to check up on
Old Dec 7, 2008 | 07:01 PM
Jay351's Avatar
My hella 500's came with 16 guage wiring. While this is fine for the switch ground,power and ground. I wired up 14 guage wiring for the relay power,ground, light wires and light grounds, I just havn't upgraded to 100w bulbs yet
Old Dec 8, 2008 | 12:00 PM
quickshot's Avatar
ok, i was thinking about wiring ill upgrade to 14 gauge wire. the 55w bulbs just arent enough from me, i want the kinda light that blinds you lol. thanks
Old Dec 8, 2008 | 03:13 PM
Jay351's Avatar
14 Guage will do you good with 100w bulbs. Just make sure you use the properly rated connectors.
Old Dec 8, 2008 | 06:20 PM
strykersd's Avatar
I just upgraded my Hella 500s to 100w bulbs a few weeks ago. The only thing I changed was the inline fuses. If I remember right they came with a 15 amp fuse and I bumped up to a 20 amp fuse.
Watts = Amps X voltage
Stock
2 X 55 Watts =110
110 watts / 12v = ~9.2amps
100 watt bulbs
2 X 100 watts = 200 watts
200 watts / 12v = ~16.7 amps
These aren't exact numbers, but just trying to show that you'll need something larger then the stock 15 amp fuse
Old Dec 9, 2008 | 11:52 AM
quickshot's Avatar
ok, well im just gonna let my friend do it (hes a toy mechanic) so i just wanted to know what to order. thanks again!
kawazx636
Oct 6, 2021 03:03 PM
SpookyMulder
Nov 4, 2015 11:56 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
89YodaRunner
Sep 30, 2015 02:18 PM
4runnerFireman
Sep 29, 2015 06:24 AM
