General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
power inverter help
Old Mar 29, 2009 | 07:17 PM
3VZRUNNA's Avatar
power inverter help
Anyone know any methods how to hardwire an 800 watt power inverter? and what is the perfect location for it? tell me waht i need. Plugging it into the ciggerette lighter socket gets in the way.
Old Mar 29, 2009 | 07:23 PM
scuba's Avatar
You need the same gauge as the wire that has the plug on it...some sauter, some heat shrink, run the whole wire through the firewall, then plug onto battery, mount inverter wherever youd like...Oh, Dont forget an inline fuse, Good luck..
Old Mar 29, 2009 | 07:27 PM
3VZRUNNA's Avatar
thanks!
Old Mar 30, 2009 | 06:00 AM
GSGALLANT's Avatar
On my 3rd Gen 4Runner, I mounted my 1000 watt inverter (1500 watt peak) under the driver's seat (bolted to floor), with the receptacles pointing out towards the driver's door. I ran the wires under the center console, under the dash, and out into the engine bay through the existing hole in the firewall just behind the blower fan. I installed a 150 amp inline blade fuse that I mounted to the firewall in the engine bay, the I connected it to my aux battery (which sits on the passenger side wheel-well in the engine bay).
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
shisha1999
Sep 20, 2015 11:44 AM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
