General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Headlights
Old Dec 29, 2008 | 01:36 PM
aadown1214's Avatar
Headlights
Trying to get my headlights wired up right.......... Passenger side works fine, but driver side is quite a bit dimmer on low beams. As for high beams, I have no clue. I thought it could be the wiring but I used my other 80 model as a standard to go by. None of the wire is frayed or cracked, etc. Apart from tracing all the wire back to the harness, the only thing I can think of is that the switch might be bad. I'm down to fumes on this one. Any thoughts or suggestions? Hopefully I'm not the only one who has had to deal with this problem.
Old Dec 29, 2008 | 01:45 PM
yota_dude's Avatar
you may wanna look at your ground wire i had the same problem but wiring back up light
4Crawler's Avatar
See wiring diagram on the page below:
- http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
For the dim light, see if you are perhaps hitting both high and low beam filaments (in series) instead of low-common or high-common. Doing so will make for a very dim light since each filament will only have about 6 volts across it. See which pins are getting power. If that is OK, check the voltage at those pins under load:
- http://www.4crawler.com/4x4/CheapTri...ml#VoltageTest
If low, likely bad wiring some place.
And realize that on Toyotas, the headlights are grounded via the headlight combo switch and they have a common power feed.
Old Dec 29, 2008 | 02:15 PM
aadown1214's Avatar
Headlight combo switch? care to elaborate a bit? When it comes to auto wiring im a dummy.
Old Dec 29, 2008 | 02:28 PM
4Crawler's Avatar
A.k.a. the dimmer switch:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Old Dec 30, 2008 | 05:37 AM
aadown1214's Avatar
Ok, i kind of figured you meant the dimmer switch. I'll take a look at it, I have a spare off my other 80 so if its bad, its no big deal I can swap that in five minutes. Thanks for the info
kawazx636
Oct 6, 2021 03:03 PM
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
