PDA
View Full Version : General Electrical & Lighting Related Topics
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13
  1. ? about charging Diehard Platinums
  2. talk about relays
  3. 96 4runner headlight/switchology problem
  4. code 51 after installing modified o2 sensor
  5. 93' v6 p/u oxygen sensor interchangeable w/ 91 o2 sensor?
  6. Where Can I Get A Off Road Light Bar For My 86 Single Cab?
  7. Getting ready to start my gen 2 Runner, motor transplant.
  8. Power windows! Need advice
  9. Pink wire 94 4runner
  10. Remote Starter / Keyless Entry Recommendations
  11. Antenna Nut
  12. i need help please!!!!
  13. Dummy Light Help
  14. break light problem
  15. Dim light
  16. wiper switch doesnt work
  17. tail/brake lights - LED swap
  18. my lights shorted out
  19. How do I change the brushes on the alternator?
  20. Is it possible? (monitor displaying guages)
  21. No high beam
  22. Fog Light Switch For My 4runner?
  23. heater control light
  24. Dome Light/Door Sensors Don't Work
  25. bulb wattage
  26. Stereo wire to fuse box?
  27. Hella Hell, wiring help...?
  28. Which Battery?
  29. Need Driving lights suggestions to fit into TJM bumper
  30. sealed beam conversion
  31. Rear Window - Sorry to beat a dead horse
  32. HID foglight light retrofit
  33. TPS wiring
  34. Stereo wiring basics
  35. 90 Truck Flasher Relay Hazards work no Blinkers
  36. cigarette lighter light bolb
  37. Am I attempting to wire my trailer harness correctly?
  38. No headlights/high beams.. BAH
  39. Aftermarket (stylish) headlights
  40. question about reverse lights
  41. Trailer-Tail Light converter bad?
  42. Hooking up an amp & sub to factory deck?
  43. Hooking up an amp & sub to factory deck?
  44. Hooking up aux. lights....
  45. Wheres the water temp gauge fuse? 94 4runner 3vze
  46. Difference between H4 and H4U...
  47. cooling fan switch?
  48. Hella FF1000 Converted HID With Hella 6054 H4 HID
  49. bttry dies when trck is running short somewhere HELP!
  50. bulb covers for dashboard
  51. 1998 4Runner Parking light replacement
  52. Need Help
  53. I screwed up and now I'm stuck
  54. signal light drawing waaay to much juice
  55. how to re-polish Polycarbonate?
  56. airbox conection
  57. identify ignition part please !!
  58. Converting Power windows To Manual
  59. Hella 500 HID Modification...
  60. Backup + Turn Sig problems -- gotta pass safety!
  61. ECU Sabotage!
  62. 94 brights lighting question/problem
  63. Digital dash shorting out...
  64. trd e-locker wiring?
  65. 3rd Gen. 4Runner Glassworks Fender Corner Lights Install
  66. amp help asap
  67. Battery last night and replaced with Diehard Platinum
  68. 98 4Runner Window switch slowly going out?
  69. 1985 toyota 4x4 head light buckets?
  70. Dome light only works when passener door open?
  71. Serious electrical Problems
  72. trailer wiring
  73. In cab control for Warn M8000 Winch
  74. 85 4runner rear window problem
  75. blown fog lights
  76. Blowing Fuses in 79 BJ40
  77. Air horn wiring ...ack frack etc
  78. Battery Disconnect Relay
  79. 1983 Toyota Pickup Wiring Schematics
  80. Dimmer/ Head unit question.
  81. Excellent, low price Rock Lights!!!
  82. anybody know the thread pitch of lightforce mounting bolt?
  83. '93 4Runner does'nt seem to like the water - Alt stops charging when wet out
  84. my 85PU no backup lights
  85. Luminics Krypton Pure Blue H4
  86. ProComp lights: Mini or Heavy duty swith kit?
  87. 84-88 Rear Heater fan switch; used for lights?
  88. Picture Request. Hella 500 Driving beam patern
  89. Big 3 wire upgrade and fusible link
  90. Wire Size for Autometer Gauges
  91. Heater control illumination bulb replacement
  92. Wiring PIAA Fog and Driving Lights - Please Help!
  93. 97runner elocker wiring
  94. AC/heater blower stopped working
  95. Who has those labeled switches for E-lockers?
  96. Tac light goes out when lights turned on
  97. airbag light problems
  98. turn signals
  99. Black-out driving 2004 4runner how to?
  100. anybody tried to rewire the 3rd Gen Aux outlets to consistent power?
  101. electric guru needed. 28v system
  102. Need wiring diagram for a 1995 4runner
  103. 99 4runner power antenna broke
  104. 86 4Runner - Highbeams stuck on!
  105. 85 4runner instrument cluster
  106. 4runner power antenna
  107. How can i get my "Maint Req" light to reset, or to manually turn it off
  108. fuse for trailer lights?
  109. cigarette lighter question
  110. Whelen SlimLighter TIR6 LED Light
  111. Alternator Help
  112. Cigarette lighter,can't get to work.
  113. PIAA 520 or 540 fogs
  114. SR5 Gauge Swap
  115. Hazards work but not turn signals
  116. Wipers cut out, rough idle
  117. A/C cut off relay question
  118. Hella H12800051 Rallye 3000 Blue Driving Lamp
  119. Moved my turnsignals
  120. should be an easy dimmer question
  121. Rear wiper doesnt work and....
  122. hella 550 who has them ?
  123. 1st gen 4runner/2nd gen pickup marker light blinker mod
  124. dash lights went out
  125. Rock lights / driving lights
  126. AC fan acting up. HELP!
  127. weird ignition problem
  128. Would two alarm LED's significantly drain battery?
  129. harbor freight off road lights
  130. 1981 Toyota Truck Wiring Diagram
  131. Combining my speedo and windshield wiper threads! please help!
  132. Where does this go?
  133. 87 4Runner brake lights inop., not the fuse or lights. What next?
  134. what's the best way to wrap up(protect) HID ballast?
  135. Electrical troubles
  136. CIG Lighter Spotlight
  137. *ASAP - Power Window Circuit Breaker*
  138. Windshield wipers not working please help!
  139. Another speedometer thread
  140. Buying a battery!
  141. ACC circuit Kaput
  142. Spark plugs
  143. HELP! electrical problem
  144. Overheating Alternator
  145. 2nd Gen Power Window Problem
  146. Battery will not recharge and alternator is good?
  147. upgrade headlights for 87 22re p/u
  148. Battery light question
  149. 87 turbo 4runner gauges
  150. Dead as a...
  151. Yet another set of rear floods
  152. Parking Light wire color - '95 4Runner
  153. Power for when IGN is OFF
  154. intermittent power loss 3.0 v6
  155. blown fuse
  156. Hella 4000s converted to HID
  157. camper shell interior light wiring question
  158. charging issues / alt swap questions???
  159. R&R motor.. need help with wiring routing
  160. electrical problems.
  161. electrical terminal tool?
  162. rpm gauge dropped to 0
  163. Electric Brake Switch
  164. V6 Tach; Convert for 4CYL (1st Gen Runner)
  165. Convert 12 volts to 9 volts?
  166. fog light switch
  167. small jumpstart battery?
  168. 91 4runner fsm?
  169. choosing fuse and switch/light help
  170. 99 Toyota Tacoma Wiring for tach to ECU
  171. Playing with conversion LED's
  172. Bad wires going to knock sensor!!!
  173. Rear wiper
  174. rack lights wiring question
  175. Brake lights don't work.
  176. I am getting a slight humming over the radio when the lights are turned on.
  177. Gauge, Shifter, Climate control lights not working
  178. wireing a 94 truck dash for a tach.
  179. Adding a Turn Signal?
  180. 12V alternator in 24V HZJ 73
  181. Oil Pressure Sender
  182. ´89 diesel popping "engine" fuse and not charging batteries.
  183. Alternator issues after wiring up dual batteries
  184. Need help w/86 radio wiring.
  185. Left Turn&Brake light issue 92 4runner
  186. high beam headlight issue
  187. Wireing Aftermarket Turning Signals
  188. Has anyone done this mod w/ the 3 prong switch
  189. 86 EFI Turbo computer problems
  190. electrical short is kicking my @#$!!!
  191. headlight ground
  192. Electric Door Locks Malfunctioning. . .'90 4Runner
  193. rewiring roll bar lights - easier in truck or out?
  194. killswitch wiring for dummies
  195. Injector plug
  196. Tacoma tail light gaskets?
  197. Turn car off headlights turn on!
  198. 91 Wirining diagram ( steering column)
  199. rear defrosters dont work!
  200. reverse lights always on...
  201. New Stereo Recommendations
  202. Strange wiper switch issue?
  203. Ignitor/Control Module. 82-83 same as 81 ?
  204. Use a FM transmitter for your Ipod?
  205. secure cig lighter inner sleeve to support ipod fm transmitter?
  206. Engine light. P0505 trouble. 98 4runner
  207. Battery Light, temp, fuel guage and turn signals not working
  208. Turn signal, hazards not working question.
  209. 86 4runner starting troubles
  210. Alternator interchange? Anything else fit a 3.4?
  211. Denso Alternator chart - anyone?
  212. Odyssey PC1700LMJT
  213. New Tach problems
  214. 1988 v6 wiring harness
  215. Has anyone smoked there own tailights
  216. rock crawler electrical ?
  217. head light voltage whats yours ?
  218. Alternator wiring.
  219. High beam wire on a 95 4runner?
  220. park lights
  221. 1988 22re fuel injection harness
  222. Off Road light help.
  223. rewireing some postive leads.
  224. 92 22re 4x4 wiring harness
  225. 97 maf pinout
  226. 22re Alternator Ugrades
  227. my brake light on top the cab don't work
  228. Back up light wiring solution needed
  229. 35W H3 bulb
  230. Round Headlights
  231. Bad alternator?
  232. Car Stereo Install
  233. stalling prob fixed
  234. IPF 55/100W lights $89 shipped at Costco. are these good?
  235. Sears Diehard Platinum = Odyssey
  236. Bed/interior cap lights?
  237. Tail lights don't work
  238. 2nd Gen HI & LO beams at same time?
  239. Voltage spike when on the gas....
  240. LED tail light retro '99 Tacoma, pics!
  241. Bad knock sensor in my 95 4runner
  242. HELP 93 yota 4x4 BATT LIGHT AND BRAKE LIGHT ON not charging
  243. Bumper mounted yellow fog light preferences
  244. Bumper mounte yellow fog light preferences
  245. 97 4run to 99 4run headlight conversion ?
  246. Thoughts on Luminics bulbs
  247. Where is the relay for rear window
  248. factory fog lght and rear window lock switch
  249. Blowning Fuses Inisturment Panel
  250. MAF ideas for boosted 22re???
