General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Stereo wire to fuse box?
Old Oct 6, 2008 | 10:58 AM
83's Avatar
83
I noticed that my stereos battery wire has been linked into a fuse in my fuse box. Is this normal? Is it a legitimate way to wire it, or ghetto?
Old Oct 6, 2008 | 11:03 AM
Elton's Avatar
sounds fine to me
Old Oct 6, 2008 | 11:17 AM
nieuwendyk-25's Avatar
Yes it needs to be fused...sometimes it has an inline fuse and sometimes it is a fuse in the fuse box.
Old Oct 6, 2008 | 11:47 AM
jason191918's Avatar
slightly ghetto, but at least it is fused
Old Oct 6, 2008 | 12:16 PM
83's Avatar
83
Ok. It just seemed a little sketchy to see a wire stuffed in under a fuse.
Old Oct 6, 2008 | 12:22 PM
Oh, that is what you meant....I have seen it done, even by "professionals", not my favorite way of doing things.
Hope they have it stuffed under the correct end or it will not be fused.
Old Oct 6, 2008 | 01:34 PM
scuba's Avatar
My radio actually has a fuse spot right in the back of it under where the harness plugs in....
Couldnt figure out why one day it just stoped working
lol
Old Oct 7, 2008 | 03:22 AM
GSGALLANT's Avatar
Is it correct? no. Will it work and be safe? Sure... as long as they picked the correct side of the fuse to connect it to. Bottom line is it's the lazy way to do it. If you're stuck for a place to get power and you don't want to install an auxiliary fuse block, then another option is using a "Mini Fuse Add-A-Circuit" to give you the extra fused 12V source.
Old Oct 7, 2008 | 06:25 AM
83's Avatar
83
I may look into something more somewhere down the road anyway. I like having another couple power outlets. I'm lucky enough to have a working cigarrette lighter in my truck still after it's 25 years, but I'd like to have more options. Wiring is still a bit foreign and scary to me, but I've got a good vehicle to start on. It's pretty basic.
Thanks!
Old Oct 7, 2008 | 08:58 PM
schmooot's Avatar
use a proper fuse tap and don't just stuff a wire under the leg
Old Oct 7, 2008 | 10:40 PM
Scooby098's Avatar
I was wondering on this subject with the fuse box, the power goes right to the battery so if you leave something on your screwed right, but with the existeing fuse box you can say put the wire under the fuse and have it were the key has to be on for it work any other way? Id like to clean up my fuse box as well.
Old Oct 7, 2008 | 10:41 PM
aviator's Avatar
Use a "Mini Fuse Add-A-Circuit" as Gallant suggested they are easy and cheap to install and may save you a ton of grief later.
MO transplant
Apr 23, 2023 11:58 AM
v_man
Jul 23, 2015 04:01 PM
jackiebrownia
Jul 20, 2015 09:02 AM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
