General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Power for when IGN is OFF
Old May 11, 2008 | 11:51 AM
Yopar's Avatar
Does anyone know how to wire up an LED light so it's ON at all times, except for when the vehicle is running? I think a relay can be used with a signal from the IGN to kill the power to the LED when the truck is running, but I'm not sure how to do it. Any ideas?
If you're wondering why, this is for an "alarm" blinking LED that I want to be on unless I'm driving; also, I don't want a switch for it, rather it be automatic.
Old May 11, 2008 | 12:16 PM
rowdy235's Avatar
Get a normally closed relay. Tap in to the "on" circuit, ground the other switch post, then run a wire from the battery through the relay to the light. Then the light will be on until you turn the key to the "on" position.
Old May 11, 2008 | 12:36 PM
Yopar's Avatar
Cool thanks, I'll try that out.
Old May 11, 2008 | 06:45 PM
Yopar's Avatar
Looks like I can just use a standard Bosch SPDT relay, and use pin 87a for the normally closed circuit.
http://www.coolcatcorp.com/faqs/relays.html
Old May 11, 2008 | 09:16 PM
Noltz's Avatar
^^ that's exactly what I was about to post. You can do that with no trouble.
Curious: Why the constant on? Alarm LED? Interior fan?
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
RustBucket
Jul 24, 2015 04:46 AM
