General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Aftermarket (stylish) headlights
Old Sep 22, 2008 | 09:11 PM
DupermanDave's Avatar
Does anyone know of a company that has made aftermarket lights for the 89 toyota pickup? Something better than the standard lights, like a xeon or whatever fillament that makes it brighter. My lights are really dim. Especially the brights.
As a secondary question, does anyone know of any ROUND lights (circular), possibly off another truck, that will fit an 89 toyota pickup? By round, I mean the round style, like on the older toyotas and all the jeeps. I like the round lights Adds personality.
Old Sep 22, 2008 | 09:16 PM
Green93's Avatar
I'm not sure about round lights, but this is what I plan on installing:
http://www.rallylights.com/hella/200mm.asp
Anything extra will be worth the price. You might have to upgrade the wiring harness if you plan on going for a high wattage bulb.
Jason
Old Sep 22, 2008 | 09:21 PM
Hilux808's Avatar
I almost went with the Hella's, I like the fact that you can change the bulbs. The brightest ones I've seen for our trucks are the Sylvania "Silver Stars". I used to run those all the time but I would have to replace them once a year, I got pretty tired of that. I live in Phoenix too so I'm sure the heat here didn't help them last long, plus they run super hot anyway. Super bright though.
Old Sep 22, 2008 | 09:27 PM
cbrsport17's Avatar
they make h4 HID kits out here in japan for the old style rectangle lights, i plan on trying to get some before i head for turkey....
Old Sep 22, 2008 | 09:40 PM
Jason
Excellent link. Thanks. Which ones should I look at buying? The 55w or what?
Also, why would I want to mess with the wiring? Isn't the standard wiring good enough?
Old Sep 22, 2008 | 10:24 PM
RiCh_90-yota's Avatar
I have a set of the Hella Vision Plus Conversion Headlights I love the beam pattern I got an H4 HID kit too make extra fancy!!!
https://www.yotatech.com/forums/f131...h4-hid-154333/
Old Sep 22, 2008 | 11:18 PM
Green93's Avatar
I'm still trying to decide which bulbs I want tot use. It seems to be a pretty personal choice, depending on conditions you drive in. And if you want them to be functional or just have the "blue" look.
If you put a 100w bulb in a spot that was designed for a 55w bulb you may get problems. This link will explain in much better than I could:
http://www.4crawler.com/4x4/CheapTri...#WiringHarness
Jason
Old Sep 23, 2008 | 08:35 AM
Jason
Which ones are the blue ones? That's the xenon ones, right? I would prefer not to have those, as those are illegal in some states.
Old Sep 24, 2008 | 07:07 AM
4Crawler's Avatar
Best to do a quick check of the existing wiring and find out if it is OK or not:
- http://www.4crawler.com/4x4/CheapTri...ml#VoltageTest
If you are getting a significant voltage drop with the current headlights (55/60 watt most likely), putting in a higher wattage bulb will not do a lot to help. And it is easy enough to upgrade that wiring:
- http://www.4crawler.com/4x4/CheapTri...l#Installation
I've run the Hella housings on my '85 for about 10 years now with a set of 55/100 H4 bulbs and the harness above. Makes a nice setup and I don't blind oncoming traffic.
kawazx636
Oct 6, 2021 03:03 PM
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
