General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Brake lights don't work.
Old Apr 8, 2008 | 09:59 AM
shortysboy09's Avatar
Hey Forum Members,
I just bought a 94' 4Runner as a project off-road truck. I'm running into a problem with the brake lights. The rear blinkers and reverse lights work on my truck but the brake lights don't. I checked the actual bulb itself and it still looks like it's still in good shape and should work. I'm wondering if there is some sort of switch to trigger the brake lights somewhere. Has anyone had this problem before? If so, some guidance on this issue would be greatly appreciated.
Old Apr 8, 2008 | 10:01 AM
4Runner202020's Avatar
i had this problem with my blinkers and i blew a fuse. check all yours.... thats my bet.
Old Apr 8, 2008 | 10:33 AM
zlathim's Avatar
Check the brake light switch.
Old Apr 8, 2008 | 11:27 AM
eric-the-red's Avatar
THe brake light circuit is pretty simple. There is a fuse, in the panel low down on the left side of the dash. There's a switch on the brake pedal, the bulbs and a ground. Start by checking the fuse. If you've got a multimeter put it on any OHM setting and see if the fuse is open. If in doubt try a new one.
With the switch take the connector off and jump it with a small piece of wire. The lights should go on. If the fuse is good and the switch is jumpered then the bulbs are probably gone. Don't just go by looks, use a meter. Again if in doubt buy some new bulbs, they're cheap.
Old Apr 8, 2008 | 12:30 PM
Ok, thanks for the help guys. I will keep ya'll updated and let you know where the problem was.
Old Apr 9, 2008 | 09:16 AM
Ok, I got it all fixed. It was the switch. Thanks for the help!
Old Mar 21, 2009 | 05:29 PM
chugs's Avatar
I have a 94 v6 pickup, I have a similar problem, tail lights work, but they do not illuminate (flash) when the brake pedal is actuated. Need some help.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Nickdigg
Jul 7, 2015 06:04 AM
colinmil
Jul 6, 2015 04:03 PM
mickyd9990
Jul 6, 2015 09:01 AM
