blown fog lights
blown fog lights
so i blew my fog lights one day when i was wheelin and they dont work now. i replaced the bulbs and that didnt do it. not sure if the fuse would be blown, what would you guys recommend i check? do you think the whole assembly and such should be replaced?
thats what i thought. is there a fuse and a relay or what? cause i found the relay in the engine compartment. im guessing the fuse would be under the steering wheel? and should i just replace both the relay and fuse or just fuse?
so i had my boss look at it and the fuse and relay were fine so he looked at the connections on the fog light itself and tunes out it was the wires and connections were filthy. he cleaned it up, got rid of that metal thing that looks like a bridge, and used two washers are the ground and connection
Flying91
45
Apr 11, 2024 04:39 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
