General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
blown fog lights
Old Aug 11, 2008 | 12:30 PM
99SR5's Avatar
blown fog lights
so i blew my fog lights one day when i was wheelin and they dont work now. i replaced the bulbs and that didnt do it. not sure if the fuse would be blown, what would you guys recommend i check? do you think the whole assembly and such should be replaced?
Old Aug 11, 2008 | 12:32 PM
904_runner's Avatar
Check the connections.
Not sure about it, but maybe the switch assembly in the steering column is out.
Old Aug 11, 2008 | 06:16 PM
99SR5's Avatar
it could be switch problem but it happened after i went through deep water so im thinkin i blew something.
Old Aug 11, 2008 | 06:28 PM
jason191918's Avatar
If you went through water, you shorted the circuit and blew a fuse.
Old Aug 13, 2008 | 07:14 PM
99SR5's Avatar
thats what i thought. is there a fuse and a relay or what? cause i found the relay in the engine compartment. im guessing the fuse would be under the steering wheel? and should i just replace both the relay and fuse or just fuse?
Old Aug 13, 2008 | 07:50 PM
No sense replacing what isn't broke. I would suspect the fuse. Easy as cake to check/replace. If that doesn't do it try the relay, but I doubt that is the problem.
Old Aug 15, 2008 | 12:38 PM
99SR5's Avatar
so i had my boss look at it and the fuse and relay were fine so he looked at the connections on the fog light itself and tunes out it was the wires and connections were filthy. he cleaned it up, got rid of that metal thing that looks like a bridge, and used two washers are the ground and connection
Old Aug 15, 2008 | 01:22 PM
904_runner's Avatar
Did it work after?
Old Aug 22, 2008 | 10:14 AM
99SR5's Avatar
yep works now. and i love it. its been about two years since they worked.
Flying91
45
Apr 11, 2024 04:39 PM
ghostmoney
Jan 28, 2018 11:42 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
toofly1999
Jul 25, 2015 07:09 PM
