small jumpstart battery?
i jumpstarted a guy earlier today and i started thinking about something. is there any way to wire in like a small motorcycle battery with a switch so that if im ever in a situation with a dead battery i can easily just flip the switch and have my motorcycle battery feed some juice into my main batt? just a simple hot line to my battery and a ground connection with a switch somewhere in between i think will work. but im not sure
or you can buy something much safer
http://www.walmart.com/catalog/produ...ci_sku=5679656
That is basically what I have on my '85:
http://www.4crawler.com/4x4/CheapTri...atteries.shtml
The batteries I run are not much larger than a motorcycle battery, in fact it is used on the '97 and newer Harleys.
And all I do is flip the switch to power the solenoid from the 2nd battery, wait a few seconds and then hit the key and it starts right up. Have done this countless times over the last 10 years.
greasyglue
Dec 12, 2015 12:57 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
