General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Battery light question
Old May 15, 2008 | 01:38 PM
davis131's Avatar
Thumbs down Battery light question
My battery light on my 97 4runner reciently came on.I had the battery out for 2 days while I installed 2 new airbags and module, I put a new battery in and the alternator IS charging. I'm at a loss. It wasn't on before, just the airbag light but the bags and module took care of that.Could that be something that has to be reset? Thanks Bill
Old May 16, 2008 | 05:46 AM
davis131's Avatar
Help please, no ones had this problem? I don't have a owners manual ,could there be some simple solution like turning the key off & on to accessory a couple times quickly or some other goofy combination to get this reset.Any help sure would be appreciated. Thanks Bill
Old May 16, 2008 | 06:03 AM
Ron Helmuth's Avatar
bring your question on over to 95 and up trucks/Runners - I don't know how to move it or if the moderators allow that or I would help you out
I am curious what controls that - could there be a fuse also to pull out and re-insert? You have the owners manual? Checked both fuse boxes?
Old May 16, 2008 | 10:01 AM
davis131's Avatar
Ron, I wasn't sure how to move a post so I just copied and pasted the question on that forum .The moderators can delete these posts if they wish.
Old May 16, 2008 | 10:18 AM
CJM's Avatar
CJM
If that light comes on it means your alt is going or the battery has a bad cell in it.
Get both checked by a qualified mechanic and NOT sears or autozone plz.
Old May 16, 2008 | 01:53 PM
davis131's Avatar
I check the alt. with a voltmeter and it seems to be putting out about 14 volts and I also pulled the + terminal with it running and it didn't die out, I also put a new battery in it and it starts fine and still no luck with the light.
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
Sandman
Jul 14, 2015 12:36 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
colinmil
Jul 6, 2015 04:03 PM
