Battery light question
My battery light on my 97 4runner reciently came on.I had the battery out for 2 days while I installed 2 new airbags and module, I put a new battery in and the alternator IS charging. I'm at a loss. It wasn't on before, just the airbag light but the bags and module took care of that.Could that be something that has to be reset?
Thanks Bill
Thanks Bill
Help please, no ones had this problem? I don't have a owners manual ,could there be some simple solution like turning the key off & on to accessory a couple times quickly or some other goofy combination to get this reset.Any help sure would be appreciated. Thanks Bill
bring your question on over to 95 and up trucks/Runners - I don't know how to move it or if the moderators allow that or I would help you out
I am curious what controls that - could there be a fuse also to pull out and re-insert? You have the owners manual? Checked both fuse boxes?
I check the alt. with a voltmeter and it seems to be putting out about 14 volts and I also pulled the + terminal with it running and it didn't die out, I also put a new battery in it and it starts fine and still no luck with the light.
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
Sandman
Jul 14, 2015 12:36 PM
