General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
High beam wire on a 95 4runner?
Old Feb 14, 2008 | 11:46 AM
timkievit's Avatar
Hey guys,
I'm trying to tap in my hellas to the high beam, so they only come on with my high beams, but I can't find the wire.
anybody know what color it is? if it runs up the fender, or the easiest place to tap into it?
tim
Old Feb 14, 2008 | 11:58 AM
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Well its the high beam wire so it probly goes right into the headlight housing, just gotta figure out wich one it is.
Old Feb 14, 2008 | 12:11 PM
eric-the-red's Avatar
It depends on whether you have DRL or not.
Without DRL then the headlights are ground switched, which means there is one live wire going in and 2 grounds coming out, one for the low and one for the high beams. The red/yellow wire is the high beam, it's the same colour on both lights.
With DRL then the lights are switched normally, on the live side, and then you want the green/white on the left side or the pink/green on the right side.
Old Feb 14, 2008 | 12:17 PM
toylocost's Avatar
Nice detailed post there.
Scotttekoch
23
Nov 1, 2021 12:41 PM
voiddweller
19
May 2, 2016 09:10 PM
saphirekosmos
Jun 22, 2015 10:26 AM
LSUMatt1514
Jun 26, 2002 05:03 AM
