General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
turn signals
Old Jul 9, 2008 | 07:45 PM
Ezrider_92356's Avatar
turn signals
my front turn signals quit working first the pasenger side one then a few mins later the drivers side one, bulbs are good and fues are good, rear turn signals work just fine, any sugestions?
Old Jul 9, 2008 | 07:46 PM
its an 89 toyota pickup btw
Old Jul 9, 2008 | 08:37 PM
4Crawler's Avatar
Check for power and ground at the actual light bulb sockets and if not present, work your way back to the connector and wiring back to the flasher relay. Might be a ground connection came loose up front.
Old Jul 9, 2008 | 08:41 PM
pepsibluefloat's Avatar
the rear still work? They blink faster than normal?
Old Jul 9, 2008 | 09:07 PM
DeathCougar's Avatar
Are you getting power to the plug? If so, then look at the bulb bases. I had this same problem, and it ended up being corrosion in the bulb socket. Cleaned it out, and it started working again.
ghostmoney
Jan 28, 2018 11:42 AM
Shoua
13
May 22, 2016 05:19 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
PopsDad1
Jul 30, 2015 02:21 PM
