General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Heater control illumination bulb replacement
Old Jul 21, 2008 | 06:10 AM
mikel48's Avatar
I am a new member and have owned Toyotas since 1980 and bought one of the first 4runner SR5s in the States in '85 and I need help on how to replace the illumination bulbs for the heater controls on my 2004 4runner limited with the navigation system. I ordered and received a new bulb, but am having difficulty getting at the back of the switch. Any help will be greatly appreciated.
Old Jul 21, 2008 | 06:18 AM
fillsrunner4's Avatar
Most the dash may need to come apart to get to the back of the control. Not to sure with the newer runners but i wouldnt doubt that you need to pull most the dash out to get to it.
Welcome BTW
Old Jul 21, 2008 | 07:32 AM
CyMoN's Avatar
https://www.yotatech.com/forums/f116...umbers-102344/
Old Jul 23, 2008 | 11:31 PM
Jay351's Avatar
Nothing about the 04 in there Crymon... No help from me. Try asking in the 04 section
Old Jul 24, 2008 | 12:34 AM
CyMoN's Avatar
look again 2nd link http://www.ncttora.com/fsm/index.html gos all the way up to 07
Old Jul 24, 2008 | 04:38 PM
Jay351's Avatar
Wow, shows how much I know.... Sorry Crymon, my bad
Old Feb 26, 2009 | 04:23 AM
mtcordova's Avatar
Did you find out?
Hi. I have the same problem. Light out in the heater fan control. I took off the knobs, pried off the plate. Tiny bulbs in there. But I don't know how to get them out. Did you ever succeed? Do I need to remove the whole panel and remove the bulbs from the rear? I looked into the manual and couldn't figure it out. WOuld appreciate any help. Mine is a '04 Pickup. Thanks.
Old Feb 27, 2009 | 12:02 AM
Jay351's Avatar
Bulb should pull out from the front..
Old Mar 16, 2009 | 08:07 AM
mtcordova's Avatar
Nope. For the '04, you remove the knobs (pull-off), then pry the face plate off (should pull off easily with fingers in the open holes left from the knobs). Then there's three screws that you remove, and the switches panel can be removed. You'll carefully move it to one side, and the other side is now cleared. Pull it slowly forward, and reach behind and unplug two wiring harnesses from the rear. Then the whole switch panel can be pulled out. There's a black "cover" on the back that snaps off. From there, you can access the tiny (really tiny) bulbs. They twist about 1/8 turn, and pull out from behind.
NOW - if I could only find replacement bulbs. I guess I have to go to the dealer for that. Nobody at my auto parts place ever saw bulbs this little.
Charecter1
Nov 6, 2023 10:08 AM
coryc85
Sep 9, 2015 06:24 AM
msane99
Jul 17, 2015 10:13 AM
madxman21
Jul 9, 2015 10:26 AM
cyclist231
Jul 7, 2015 12:56 PM
