General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
talk about relays
Old Oct 29, 2008 | 07:07 PM
4runnerguy's Avatar
talk about relays
so what is the diff between having a relay or not for your 4x4 lights
Old Oct 29, 2008 | 07:24 PM
Tofer's Avatar
Sponsor
the difference between fires and not.....
Old Oct 29, 2008 | 07:32 PM
scuba's Avatar
x2 !!!
Old Oct 29, 2008 | 07:33 PM
4runnerguy's Avatar
well i do have a fuse so that will not happend
Old Oct 29, 2008 | 07:36 PM
jason191918's Avatar
A relay allows you to use a switch on low voltage/current wiring, instead of the high current wiring. Also, it is easier to route smaller wires in the cab than the larger wires for the lights.
Old Oct 29, 2008 | 08:19 PM
4Crawler's Avatar
The other advantage of a relay is that you can locate the relay close to the battery and lights to minimize the amount of (heavy gauge) wire needed and to maximize voltage at the lights for best brightness. With a switch on the dash you'll be running a wire from the battery back through the firewall to the switch then back through the firewall to the lights then some sort of ground path that ends up back at the battery. With a relay you go from battery to relay to lights and then the same ground path. Also with the relay you have added flexibility in that you can wire the relay to only be able to turn on when say the headlights or parking lights are on (and turn off when those lights are turned off).
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
