General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Wireing Aftermarket Turning Signals
Old Mar 15, 2008 | 11:00 AM
JasonWin's Avatar
I was told I need bigger turning signal lights for inspection( the ones that came on it were way to small). I did a test wireing before I try to mount them, The only problem was they seemed to be way to dim. I assume I just need to run some more power to it But how would I go about doing that? Is there a way to run more power that would only work with the turn signal? or should I run power to it that come on upon ignition and the blinker signal will just make it brighter? It's an 85 pickup by the way but there's been allot of aftermarket work done to it so I'm not sure how stock the wireing is.
Any help would be greatly appreciated, thank you.
Old Mar 15, 2008 | 12:52 PM
element's Avatar
You could probably use a relay. Use the existing turn signal wire to energize the relay. And run power to the lights directly from the battery.
Old Mar 15, 2008 | 12:59 PM
element's Avatar
This is very similar to what people are doing to “upgrade” their headlight harnesses. More info is found in the thread below and in 4Crawler’s link
Originally Posted by 4Crawler
If that is measured at the back of the headlight connector under load, that is pretty good. You want to be within 0.5 volts of the battery voltage with the headlights on for optimum light output:
- http://www.4crawler.com/4x4/CheapTri...ml#VoltageTest
Basically you would be doing the same thing, but your blinker would trigger the relay instead of the headlight wire.
Old Mar 15, 2008 | 07:08 PM
JasonWin's Avatar
Ok I feel kinda stupid now, it was a pretty easy fix the lights I got had a red and a black wire coming from them I just automatically asumed live and ground right? Wrong both were suposed to be live (for when they're installed as brake/turn lights) So I just wired both wires to the blinker wire and it works great.
Thanks for the reply anyway thought, if I ever run into a similar problem I'll be sure to use a relay.
MO transplant
Apr 23, 2023 11:58 AM
gary4runner
Sep 24, 2015 12:53 AM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
Suprarossa
Jul 6, 2015 05:21 AM
