General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
SR5 Gauge Swap
Old Jun 24, 2008 | 06:53 AM
83's Avatar
83
SR5 Gauge Swap
Hey, I got a dash & instrument cluster from an SR5 truck. Mine is non-SR5. I don't see any wires with the cluster..thought I told the guy to include them, but oh well. Do I need wires from it to connect everthing up, or is it all in my truck already, just needing to be connected to the gauge? Also if anyone's done it and has any advice, I'd appreciate it. I got a write-up of the numbers & wire colors for the swap, but that's it. Thanks!
I'll go ahead and post what I have in case it's helpful to anyone.
SR5 non-SR5 wire color function
1 1 GY Right turn signal indicator
3 3 BR (B BR) Speed sensor (-) ground
4 6 GL Speed sensor (+)
7 23 YG Water temp gauge
8 9 RW Panel lights (+)
9 15 YR Fuel Gauge
10 12 Y Ignition switched power
11 21 YB Oil Pressure switch (idiot light)
12 22 YW Charge (idiot light)
13 14 WB Ground
14 Tach input - must be wired to igniter
yellow
15 17 GB Left turn signal indicator
16 16 RB Panel lights (-)
17
18
19 11 G 4WD
20
21 19 BY Seat belt
22
23 13 RG High Beam
24 20 GW Brake
For some reason it's not spacing out the way I'd like, but the first row is SR5 numbers, the second is non-SR5, third is wire color, fourth is function, in case it doesn't make sense.
Old Jun 24, 2008 | 06:57 AM
ozziesironmanoffroad's Avatar
everything is plug and play except for the oil pressure sender. and depending on how your truck is wired, you may have to run a tach wire
Old Jun 24, 2008 | 07:53 AM
83's Avatar
83
Ok, thanks. So if he didn't give me any wires with the cluster, I'm ok with the wires in my truck already? I don't need to find a wireing harness (aside from the tach depending on my truck)?
Old Jun 24, 2008 | 07:57 AM
ur fine. just remember to change out the oil pressure switch with the oil sending unit
Old Jun 24, 2008 | 11:25 AM
83's Avatar
83
Cool, thank you.
Old Jun 27, 2008 | 07:58 AM
83's Avatar
83
Now......Um.........so, if someone were to want to change the odometer.....how would such a person do that? Of course it's illegal and of course no one would do this, but say you swapped instrument clusters, I mean if you're actually trying to return the odometer to what the truck has on it....would that really be wrong?
I can't say that I want my odometer to read what the donor truck had on it, and even though having it start at zero sounds kinda cool (especially since my engine and transmission will be rebuilt), I'd prefer it said my actual mileage.
Anybody heard of how this might be done, just hypothetically, of course.
Old Jun 27, 2008 | 09:42 AM
874runnersr5's Avatar
Put it on blocks and drive in reverse
all jokes, i just had to say that. lol
Old Jun 27, 2008 | 10:00 AM
find someone who knows how to take apart the assembly, then have them set the mileage to what your truck has on it. i have yet to do this, in fact im kind of thinking of putting my dlx cluster (big speedo) back in...
Old Jun 27, 2008 | 10:30 AM
83's Avatar
83
Ok, thanks. I'll see if I can find someone who will do it.
Old Jul 7, 2008 | 06:39 AM
83's Avatar
83
What's the deal? Everyone I've talked to says that the 79-83 instrument panels are all interchangeable............Have a look.
Is there any way to make this work, or am I back in the market for an instrument cluster? The top cluster is the one out of my truck, an '83. The lower is out of an '82 and I'd sure like to get it in my truck..
Old Jan 9, 2012 | 01:11 PM
Weigle's Avatar
I have an 82 and mine looks like the one on top. The 83 and 82 should be identical I believe... Did you ever find a solution?
Old Jan 18, 2012 | 04:49 PM
Stafford92's Avatar
Here is what i found looks pretty simple.
http://www.youtube.com/watch?v=reYkxh3ETeU
Old Jan 18, 2012 | 04:51 PM
Stafford92's Avatar
On the topic i have an 85 sr5 4x4. The tach doesnt not work nor voltage gauge or water temp. i like the cleanliness of the stock cluster and would like to get it to work any ideas on where to start? at least the tach?
Flying91
45
Apr 11, 2024 04:39 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
88yodabasket
Jul 13, 2015 01:32 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
