General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Hazards work but not turn signals
Old 06-22-2008, 03:41 PM
alphaniner's Avatar
I just bought a 92 pickup a few weeks ago. In the process of doing some rewiring for the front right turn signal bulb, I managed to pull off a double whammy. I reversed the wires and put in the wrong bulb: I used single filament rather than a dual filament. When I went to test the signal, the interior indicator light came on for a split second (I think) then died. I fixed the screw ups and now my hazards work fine but my turn signals don't work at all. I checked all the fuses in the box in the engine compartment and they are all good. I also tried a new flasher module but that didn't change anything. I know they were working before I started farting around. Does anyone have any suggestions? Thanks.
Old 07-01-2008, 04:51 PM
Jay351's Avatar
So, when you turn on your 4 ways all the signals work fine? Outside and in?
Old 07-02-2008, 06:26 AM
eric-the-red's Avatar
Check the fuses inside, under the dash on the left hand side. #9, which is the bottom right, is for the turn signals.
Old 07-06-2008, 02:17 PM
rowdy235's Avatar
also the hazards and the blinkers use different flashers, you could have blown your blinker flasher. I'm not exactly sure where it is.
Old 07-06-2008, 03:41 PM
86tuning's Avatar
^^ negative ghostrider.
The hazard and blinker flasher is the same unit.
Usually, if the hazards work, you have a signal switch problem of some sort.
Cheers.
06-01-2021 01:51 PM
colinmil
07-06-2015 04:03 PM
HRDC0R19
07-05-2015 06:43 PM
aciorba23
06-29-2015 04:18 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Hazards work but not turn signals
