General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
electric guru needed. 28v system
Old Jul 7, 2008 | 07:01 PM
ETRNL's Avatar
i am looking for someone to help me build/convert a way to run 2 sets of lights with the following specs out of my 4runner...
28vdc
5amp
250w
should be simple, i hope..
anyhow plese let me know if you can help.
THNKS ETRNL
Old Jul 7, 2008 | 08:31 PM
4Crawler's Avatar
Search for "DC to DC converter":
http://www.google.com/search?q=dc+to...ient=firefox-a
Old Jul 7, 2008 | 08:59 PM
ETRNL's Avatar
ok so i tried just using 2 batteries and that looks to be easier. now, how does one go about charging 2 batteries in series with the stock alternator?
Old Jul 7, 2008 | 09:15 PM
4Crawler's Avatar
Hard to do directly. One option would be a series-parallel switch or relay so you could put the batteries in parallel to charge, then switch them to series mode to power the load. Depending on how long the load needs to run and how big the battery is (Amp-Hour rating), that may work. Or you might be able to rig up some sort of electrically floating battery charger for the 2nd battery (essentially a DC-DC converter). Or add a 28 volt alternator to the engine or make up a motor-generator unit (12V motor driving a 28V alternator) and use that.
TACOJO
Nov 27, 2015 05:26 PM
coryc85
Sep 9, 2015 06:24 AM
bvleonov
Aug 22, 2015 11:39 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Esibnitsud
Jul 30, 2015 08:21 PM
